What do you put above a corner fireplace?
I have a corner fireplace in my new condo that I'm closing on soon, I have no clue what to put over it. A plant? I couldn't really put a painting since its in the corner. Any ideas?
6 Forward 1 Back
Couldn't you mount one of those swing arms for Plasma/LCD tv's and have one above it?
is learning to moonwalk i
Is that a working fireplace? Where is the flue?
Is it too late to have the builder close the corner above it off with drywall? If it is too late, you sould still get a painting and hang it from the ceiling so it matches the angle of the fireplace.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Some corner glass shelving to use as a display for various things.... Or close it in with drywall and have the lines of the fireplace continue right up to the ceiling.. Or just leave it empty/as is and have it all blend and disappear into a nice wall colour (whatever you're painting).
Its already painted, but I never thought of corner glass shelving. I like that idea.
Originally Posted by fdl
Or just put stuff on top, small pictures, etc.
Lots of tiny trinkets and pictures will look busy and get lost in the room. To make it a focal point, keep it clean, simple, with just a few fitting pieces to grab your eye when you walk into the room.
^ Buy a few things that are all totally different from each other in scale, colour, theme, etc. and try them all out. Keep the items you think work and take the rest back. Can always try more than one thing just to get an idea of what looks best.
Have fun!
What colour is the room?
Have fun!
Most people have TVs on top...I've elected to keep a TV out of the living room since no one ever talks anymore during parties...so, I just have some nice vases on there.
This is an old pic as I've since moved the horse to the TV room upstairs...
![](https://farm1.static.flickr.com/53/185302302_414b39a018.jpg?v=0)
Have fun!
Have fun!
The color of the room I would best describe it as a slightly lighter version of Bailey's Irish Creme.
Yummy, I don't want to put the TV there, the connections are all on the wall, I don't feel like moving them or running a cable up to the fireplace.
Vases, decorative plates, and/or sculptures will do it.
Another easy way is to buy one large vase that's bright color and just do a giant bouquet of either dried flowers or fake flowers. That looks nice too.
It's a great place for a hookah collection.
Put something on both walls of the corner, don't just try and place something in the corner.
You could also build the wall up from the f/p to flatten out the corner. I'm surprised that they didn't do that in the first place. Looks like the were cutting corners.
Fuct in the hed!
![](http://i50.photobucket.com/albums/f340/NickyPass/AFTER.jpg)
Chloe @ 17mo
hmm... maybe a blown glass vase with some bamboo posts.... or that long grass stuff
Crate and Barrel probably has something
Crabcakes and Football!!!
Cutting corners.....I see the red, but I think its to save space. Honestly corners are often wasted space. I'd rather have a fireplace there than on a larger wall where I could place a couch, tv, painting, etc
^^^ No, I'm not saying anything about the actually space. But to build a room and just place a f/p in the corner like that, to me is cutting corners as far as the build.
I had a f/p like this in a old condo, but the builders built the wall up to the ceiling, it just looked better IMO, like Nicky Pass is showing.
It think I would build something above it while add shelfs to it. What you have is hard, I suck at trying to design or pretty up a room.
Nicky's picture appears to be a woodburning fireplace with a vertical flue, while cTLGo's is a gas only job with a rear vent. The wall to the ceiling is necessary for the venting on the wood burning fireplace.
I think it does look better with the wall all the way to the ceiling.
I'd say the vent goes straight back to the outside, maybe with a little vertical tilting for proper venting. You'll see it looking out those doors.
Team Anthracite Member
It has to be vented - otherwise you could die while using it.
as far as what to do with it....
I would frame it out to the ceiling and do a real nice stacked stone look...in-laws had a stacked stone fireplace in their previous house - real eye catcher.
non venting, just checked, pulled out the gas logs and moved the burner, there is NO ventilation. All I have to do is crack open the patio door to the right a lil to vent air. Its lame, I barely would the fireplace, it honestly would have not been too hard when they built the place to channel from ducting straight out.
you should call someone - that is not safe. you gonna crack the door when it is raining out or the middle of winter? - get outta here -
that is a BS rig job they did.
On the fireplace venting, its similar to burning your stove, burns natural gas, pretty clean.
On the physical fireplace, I went to Hobby Lobby this weekend (highly recommend this place if you need inexpensive and nice decorations) and bought 3 large candle holders various lengths and 3 big candles and arranged them triangularly and offset one another. I'll post a pic later tonight.
cycdaniel
12-17-2019 10:58 AM
