Wall Touch Up
Old Oct 15, 2009 | 07:03 PM
Whiskers's Avatar
Go Giants
Wall Touch Up
Has anyone successfully touched up their walls and been able to match it? I used the leftover paint and it looks way different after it dried What am I doing wrong?
Old Oct 15, 2009 | 07:13 PM
Dr. Colorado's Avatar
Depends how long you had the leftover paint. I used off-white for my interior and tan for the exterior and didn't have any problem reusing leftover paint within 1 year. I'm sure certain paints oxidize or degrade to some extent over time affecting color. The flipside is that the paint on your wall changes color over time, especially with UV exposure or if you live close to the ocean as with my home. I will usually chip a small paint flake off with a sharp blade and take it to the paint store. This provides the most accurate match IMO.
Old Oct 15, 2009 | 07:14 PM
Whiskers's Avatar
Go Giants
^Great advice....So if I really chip off a piece, you think they can match it up pretty well?
Old Oct 15, 2009 | 07:36 PM
Yeah, at Home Depot they have some scanning device connected to a computer. The computer algorithm directs the appropriate mixing of the paint.
Old Oct 15, 2009 | 07:40 PM
svtmike's Avatar
Did you mix it up really thoroughly?
Old Oct 15, 2009 | 09:10 PM
subinf's Avatar
One on the right for me
I've had pretty good luck with painting smaller areas several years after the paint was first applied. Like svt said, make sure you mix up the paint really well and paint a bigger patch.
If it is a wall that gets a lot of light, then take it piece down to the paint store. They will be able to get you a pretty solid match. Like rick said
Old Oct 15, 2009 | 09:50 PM
NSXNEXT's Avatar
Surprised you didn't just buy a new house.
I agree with the paint chip. But you're going to have to feather the edges of the touch up.
Old Oct 15, 2009 | 09:53 PM
For sho. I may even do a little fine sanding at the edges for a better blend between the new and old paint.
Old Oct 16, 2009 | 12:09 AM
AdamNJ's Avatar
Make MyTL Great Again
It depends on the sheen of the paint. Anything with a sheen, when touched up, you will be able to notice it. I don't know how to 'get around it' other then repainting that entire wall.
Old Oct 16, 2009 | 12:42 AM
subinf's Avatar
I've repainted spots of high gloss kitchen paint and haven't noticed much of a difference
Old Oct 16, 2009 | 06:34 AM
Whiskers's Avatar
Go Giants
How big does the paint chip sample need to be?
I thought I did, but I will for the next batch.
Im highly considering it. I did sand the edges though.
This is a big difference, the old painted wall is much darker and not as yellow as the touch up spots.
Thanks all. My project for today is here.
Old Oct 16, 2009 | 09:12 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Whiskers it's not going to be a perfect match. To the untrained eye, it might be good enough, but for you, it most likely will not be good enough. I have had to repaint entire sections of walls to get the paint to "match", or at least blend in with the surrounding paint. What I mean is, if the object we say, a square column, I would paint the entire side of the column that needed it, floor to ceiling. You can't notice a difference between each side, and you have better coverage.
Old Oct 16, 2009 | 10:15 AM
Whiskers's Avatar
Go Giants
Meh, I used the wrong color yesterday...Found the right one today...Im a dumbass....
Old Oct 16, 2009 | 10:23 AM
Will Y.'s Avatar
Registered but harmless
Hey, didn't you once use brush paint on a car in England??!
Good luck on the touch-up, but it may still be noticeable unless done per Gatr's post. It may be OK if the color is a flat color and the old paint is fairly new.
Old Oct 16, 2009 | 10:26 AM
95gt's Avatar
Outnumbered at home
classic.
Old Oct 16, 2009 | 11:08 AM
Whiskers's Avatar
Go Giants
It looks fine now :duh:
Old Oct 16, 2009 | 11:18 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
LOL. Whiskers, what you need is Tim Tebow sperm, that way the walls won't chip.
Old Oct 16, 2009 | 11:21 AM
subinf's Avatar
well at least you didn't repaint the entire wall
Old Oct 16, 2009 | 11:22 AM
hornyleprechaun's Avatar
Bent = #1
Old Oct 16, 2009 | 11:33 AM
Whiskers's Avatar
Go Giants
I said it before and Ill say it again....Im not handy...
Old Oct 16, 2009 | 11:35 AM
svtmike's Avatar
We'll know to take our troubleshooting questions down a notch next time.
Old Oct 16, 2009 | 11:37 AM
subinf's Avatar
At least it isn't as bad as thinking your refrigerator has a flux capacitor
That was the funniest H&G thread
Whiskers's Avatar
Go Giants
Step 1: Make sure you are using the correct paint.
Step 2: Repeat step one.
Old Oct 16, 2009 | 12:13 PM
svtmike's Avatar
Zackly.
Old Oct 16, 2009 | 12:17 PM
subinf's Avatar
EurTSX?
Old Oct 19, 2009 | 07:05 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
This reminds me that the best answer is the simplest one.
Old Oct 19, 2009 | 12:26 PM
moeronn's Avatar
is learning to moonwalk i
... oh wait... this is H&G, not D&R.
This is the equivalent of you doing tech support for computer newbs.
Old Oct 19, 2009 | 02:26 PM
Whiskers's Avatar
Go Giants
Old Oct 19, 2009 | 07:14 PM
Gfaze's Avatar
S E L L
Old Oct 26, 2009 | 09:49 AM
dallison's Avatar
registered pw
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
polish_pat
Sep 30, 2015 12:22 PM
jmaxima03
Sep 27, 2015 10:22 AM
TL14
Sep 24, 2015 04:37 PM
