Toilet question
Old Mar 3, 2006 | 03:49 AM
TypeS_boi's Avatar
CL-S retired 10.17.06
Toilet question
How do I get the toilet to flush or go down faster??? Moved into our place like 2 months ago and this has been buggin me so I changed the innards of the tank but its still the same. Here's the deal, I set the water level maybe an inch below the line where the water level line is marked. Flush and the water kinda rises and then goes down kinda slowly. Is this a gravity thing or can I do something to make it flush with better pressure. I've looked at the toilet tanks at work and they look the same but it'll flush like it could suck someone in! I want THAT flush!
Old Mar 3, 2006 | 06:32 AM
TXXXX's Avatar
Horny.
Your drain maybe clogged?
Old Mar 3, 2006 | 07:49 AM
pmptx's Avatar
Honda+Blue=My garage
You should have it fill to the line. It is slow, because you don't have enough water volume.
I had the same issue 2 weeks agoa dn a turn of the adjustmwent screw to bring the water level up fixed it.
I thought it was a drain clog at first also.
Old Mar 3, 2006 | 07:58 AM
TXXXX's Avatar
Horny.
I should have said partially clogged.
Old Mar 3, 2006 | 09:28 AM
NSXNEXT's Avatar
Those are pressure assisted toilets. Lot's of manufacturers make them.
Check www.kohler.com to see examples.
Old Mar 3, 2006 | 11:11 AM
TypeS_boi's Avatar
it's not clogged cuz I snaked it when we first moved in. I raised the water level, helped a lil bit. I just might invest in one of those kohler toilets. $442 is pretty steep but the bathroom is my sanctuary! Thanks guys
Old Mar 3, 2006 | 11:15 AM
fuzzy02CLS's Avatar
Ok, how about this....
How do you make the toilet flush all the way. Right now I have to hold down the handle to get the thing to go all the way down. If not it never completly flushes.
I tried adjusting the flapper, handle, & water level, it helped a little but not much.
Old Mar 3, 2006 | 03:25 PM
xjdmb16a2six's Avatar
7thGenAccord
^^^ try to adjust the chain.
Old Mar 3, 2006 | 04:46 PM
DanL's Avatar
Could also be a vent issue, especially if the toilet is 'new construction', i.e., added after the house was built such as in a finished basement.
Old Mar 4, 2006 | 02:46 AM
TypeS_boi's Avatar
pressurized toilets should be mandatory! I mean, nobody want to find any presents floating around and it's embarrassing if you have company over and they hear you flushing more than once! :
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
