Spray foam insulation
Old 04-12-2011 | 09:41 AM
KaMLuNg's Avatar
i will be finishng the basement soon and need to start thinking how i plan on insulating the foundation walls... normally i would go with gluing 3/4"-1" rigid inslation to the walls and then studding over them and another layer of fiberglass batt before sheetrocking...
but i have been watching alot of HGTV and it seems like they are starting to move toward spray foam insulation. i looked online for a DIY kit and they seem pretty expensive. wondering if any of the aziners had any experience with this stuff???
TIA
Old 04-12-2011 | 10:14 AM
dallison's Avatar
registered pw
I have never used it, but i think that might be a job for the preofessional. They will prob have better equipment to make it easier to apply w/o any of the mess.
Old 04-12-2011 | 11:15 AM
KaMLuNg's Avatar
if a DIY kit is running $600, im thinking hiring a pro to come and do it will easily be a 1-1.5k job... i may go with ol faithful on the rigid stuff if that is the case... hmmm ...
any others?
Old 04-12-2011 | 11:22 AM
av6Batmobile's Avatar
your not going to see it in years so just go with regular insulation, and if you nee to repair or happen to replace a certain spot, you can just go to home depot and replace yourself
Old 04-12-2011 | 11:49 AM
fsttyms1's Avatar
It is something i would pay a professional to do. When i build my home in the near future it is one of the very few things i will pay someone to do.
Old 04-12-2011 | 11:50 AM
dallison's Avatar
registered pw
why not go with the rolls and a vapor barrier? How long are you planning on staying there?
dallison's Avatar
registered pw
and mudding drywall.
Old 04-12-2011 | 11:55 AM
fsttyms1's Avatar
Nope, i will do that. I have gotten very proficient with it. Digging the foundation, HVAC are really the only 2 things i wont do. I will do every thing else myself (between friends in the trade and myself we can do plumbing and electrical) building will be a snap.
Old 04-12-2011 | 11:58 AM
dallison's Avatar
registered pw
You most def save a lot of cabbage being in your industry.
Old 04-12-2011 | 02:46 PM
KaMLuNg's Avatar
maybe another few years... def not my forever house... so that is why i was thinking about going the cheaper route...
i still can't get my joints perfect yet when i mudd... i find myself sanding alot and just wasting the spackle...
Old 04-12-2011 | 02:55 PM
NSXNEXT's Avatar
Go with just fiberglass insulation. No need to do rigid and fiberglass.
Old 04-12-2011 | 03:54 PM
dallison's Avatar
registered pw
don't spend the extra money.
Old 04-12-2011 | 04:51 PM
KaMLuNg's Avatar
i thought the rigid acts as a vapor barrier... or do i just stud the walls directly on the concrete foundation walls and get the fiberglass special for the basement walls...
Old 04-13-2011 | 03:41 PM
dallison's Avatar
registered pw
Do you need to frame your basement before adding the drywall? I would think so but not too sure. If it has to be framed, i would use the rolls and vapor barrier. I thought the barrier was the thicker plastic that you stapled up?
And then the drywall would go up. I am not sure of the proper way, but i'm not sure about any area below ground level, if it is below ground level.
Old 04-14-2011 | 02:50 PM
NSXNEXT's Avatar
Installation
1) Vapor barrier (6mil poly is fine) directly against foundation
2) Kraft-faced insulation with paper facing sheetrock
3) Sheetrock
If you have water issues you can also paint Dry-lock on the foundation walls prior to the vapor barrier.
Old 04-14-2011 | 02:54 PM
NSXNEXT's Avatar
I used furring strips and masonry nails to attach it.
Old 04-14-2011 | 03:36 PM
Scrib's Avatar
Administrator Alumnus
I would not invest in foam insulation for a basement finish. Yes, the foam gives you a better R-value, but it's a basement and will ALWAYS be cold. Save the money (like others said), spend it on something else.
MrHeeltoe
20
02-23-2023 01:54 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Spray foam insulation
