my bubb is dirty
Old Jun 18, 2007 | 05:26 PM
Marc S's Avatar
my bubb is dirty
im tryin to get my piece nice and clean. i was wondering what works the best and more importantly, any household items i can use to clean it?? thanks
Old Jun 18, 2007 | 05:28 PM
dreem1er's Avatar
deal with it
just don't use anything flammable....
NetEditor's Avatar
Big White Chocolate
I'm really afraid to ask what your "bubb" is.
revitupwriteitoff's Avatar
:ibbubbrubb:
Whiskers's Avatar
Go Giants
If you are talking about a toilet then move to H&G
If you are talking about your ass, then move to D&R
Old Jun 18, 2007 | 05:33 PM
wndrlst's Avatar
Earth-bound misfit
+1!
Old Jun 18, 2007 | 05:34 PM
Shadzilla's Avatar
Whatever it is, give it a good scrubbing with some sandpaper, to really work the dirt out. Then, finish by rubbing it with a mixture of salt and lemon juice to sterilize the area and kill any bacteria.
Old Jun 18, 2007 | 05:45 PM
dallison's Avatar
registered pw
having the nerve to ask how to clean you bubb.........priceless
Old Jun 18, 2007 | 05:47 PM
levon1830's Avatar
It's best left uncleaned. Everyone knows that.
Old Jun 18, 2007 | 05:48 PM
mattg's Avatar
dip it in 99% rubbing alcohol
Old Jun 18, 2007 | 05:50 PM
Marc S's Avatar
hahaha... knew the heading was screwed up since alot of non smokers are gonna be reading this. bubb = bubbler
Old Jun 18, 2007 | 05:52 PM
Schizm's Avatar
Synaesthesia sounds sweet
Formula 420 ftw. Do they sell that in your area?
Old Jun 18, 2007 | 07:53 PM
herbalist's Avatar
chips and smokes, lets go
i always used Purple Power for my glass pieces.
http://www.purplepower.com/
Old Jun 18, 2007 | 11:10 PM
Schizm's Avatar
lol at the move to H&G
One method that works but really stinks your place up is boiling it for a few minutes.
Old Jun 18, 2007 | 11:24 PM
shnee's Avatar
Land of Pleasant Living
if it's glass, i don't advise boiling it, although it will get all the resin right off.. but you run the risk of busting the glass, and that's no good
my most successful method is rubbing alcohol and table salt.
first, soak the piece in a bowl of hot (not boiling) water to loosen things up.
then fill the piece up with rubbing alcohol.. make sure you plug up the holes.
let it soak for a few minutes, then pour in a generous amount of salt (as an abrasive)
shake it up really really well...
shake some more.
eventually, that should take care of most of it.
rinse well with hot water.
on my bigger pieces, i use hookah brushes along with this method.
works like a charm.
i've used a few pieces for a while, used this method to clean them out, and then sold them as new and they basically were.
Old Jun 19, 2007 | 06:34 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
WTF is a bubb?
Old Jun 19, 2007 | 07:51 AM
The Dougler's Avatar
Unofficial Goat
Bong
Old Jun 19, 2007 | 10:20 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Originally Posted by The Dougler
Bong
I guess you learn something new everyday! Acurazine FTW!
Old Jun 19, 2007 | 10:39 AM
phipark's Avatar
Not Asian
gasoline
Old Jun 19, 2007 | 11:48 AM
shnee's Avatar
Bong
as i understand the differences:
bong: larger.. suck for a while to fill it up with smoke, then pull the slide or let off the carb and take all the smoke at once.
bubbler: smaller.. basically a pipe that filters through water.. not a real "clearing" of the chamber, because it's too small to really build up a lot of smoke.
bubblers tend to look more like pipes too, although i have a few bubblers that look just like mini bongs.
of course, there are so many different styles and variations to bongs, bubblers, pipes, etc. that this is not a completely accurate description, but it should give you a good general idea.
EX:
"hammer" bubbler:
notice the stem coming down into the basin, which is where the water sits.. the smoke gets pulled through the water and pretty much straight to your mouth.. you see and hear very small bubbles, but as you can see, there isn't much room for smoke to gather.
"bubble bottom" bong:
you can see there is a lot more room for water, and a lot more room for smoke to collect. this allows you to pack the chamber full of smoke, and then pull the slide, and inhale it all in one big hit.
the bubbling is usually much louder and obvious, and is what you usually hear in songs.. the bubbler gives a much quieter, whimpier bubbling sound.
Old Jun 19, 2007 | 12:11 PM
BEETROOT's Avatar
Yeehaw
I thought he was talking about his ass.
Old Jun 19, 2007 | 12:20 PM
herbalist's Avatar
EX:
"hammer" bubbler:
pothead
Old Jun 20, 2007 | 01:14 AM
shnee's Avatar
Originally Posted by herbalist
pothead
So did you get it clean, Marc?
Old Jun 20, 2007 | 03:48 PM
mattg's Avatar
i thought he was talking about his twig. my answer is the correct one regardless.
JByron
Jan 8, 2016 09:49 PM
Silvermoon_Knight
Oct 22, 2015 06:25 PM
lland
Oct 4, 2015 04:47 PM
hrothgar02
Sep 28, 2015 11:08 AM
sputik
Sep 7, 2015 01:40 PM
