Low Voltage Lighting
Old Jan 29, 2006 | 10:19 AM
Whiskers's Avatar
Go Giants
I just ripped out the low voltage lights in front on my house (they were old and done). Im left with two wires that don't seems to have any markers (stripe on one). When I get the new lights, does it matter which wire goes where or is it just to complete the circuit?
Old Jan 29, 2006 | 10:29 AM
soopa's Avatar
The Creator
i would think the striped wire would be your hot (black) wire.
Old Jan 29, 2006 | 10:33 AM
Whiskers's Avatar
Go Giants
Ill check again, but I didn't see a striped wire.
Old Jan 29, 2006 | 10:42 AM
Scrib's Avatar
Administrator Alumnus
Who is the manufacturer? From what I recall when I installed mine, you didn't have to worry about what you're asking. I have Malibu lights and transformers.
Old Jan 29, 2006 | 10:45 AM
Scrib's Avatar
http://www.intermatic.com/images/ins...-900_11350.pdf
Old Jan 29, 2006 | 10:47 AM
Whiskers's Avatar
Go Giants
I check. If I yanked the lights off the right way, there were prongs on the end.
Old Jan 29, 2006 | 10:59 AM
doopstr's Avatar
It's DC and the light is just a resister so it shouldn't matter which way you hook it. It could matter if you get LED lights. They only light up in one particular direction. They wouldn't blow up though, they just wouldn't light.
Old Jan 29, 2006 | 11:03 AM
Whiskers's Avatar
Go Giants
Originally Posted by doopstr
It's DC and the light is just a resister so it shouldn't matter which way you hook it. I could matter if you get LED lights. They only light up in one particular direction.
These aren't LEDs....
Old Jan 29, 2006 | 01:50 PM
soopa's Avatar
The Creator
ah... i thought you were saying that one WAS striped.
Old Jan 29, 2006 | 02:30 PM
GreenMonster's Avatar
These are DC, so the polarity doesn't matter... (Just like Scribby said).
Heck, if it were AC it probably wouldn't mattter as alot of household outlets have the plugs hooked up backwards anyways (even on new construction)....
Old Jan 29, 2006 | 07:08 PM
cM3go's Avatar
just touch the wire, don't be a puss it won't hurt...
much...
Old Jan 29, 2006 | 07:43 PM
Scrib's Avatar
much...
Actually, it won't. That's the beauty of low voltage lights. The transformer takes things down from 110V to just 12V. During the install, you're to have the power on when attaching the lights to the cable.
Old Jan 29, 2006 | 07:48 PM
Whiskers's Avatar
Go Giants
Old Jan 30, 2006 | 01:58 PM
Scottman111's Avatar
1919
I don't know what you've found out Whiskers so not sure if this matters, but the neutral wire will sometimes have a line or a ridge that runs the length of the wire.
It's usually not colored but you can run your finger along it and feel it.
Old Jan 30, 2006 | 02:11 PM
Whiskers's Avatar
Go Giants
Since it's like 8- degrees out, Ima gonna check when I get home. Thanks.
Old Jan 30, 2006 | 02:38 PM
doopstr's Avatar
Hmmm, a 9v battery will make my tongue tingle. I wonder what a 12V wire would do. I bet it has more amps than a battery
Old Jan 30, 2006 | 05:42 PM
Whiskers's Avatar
Go Giants
The two wires are identical, no ridges or stripes.
Old Jan 30, 2006 | 06:01 PM
1919
Well if that's the case I'd say it wouldn't matter at all. I'm actually really surprised though, usually they'll mark it somehow even if it doesn't matter
Old Jan 31, 2006 | 08:56 AM
Scrib's Avatar
Not really... V=IR... So you can increase the voltage, and the resistance and keep the amps the same. I don't think the current going through the wire is much of anything.... It can't be, or the company couldn't allow the install to be as easy and hands on as it is....
Old Jan 31, 2006 | 09:16 AM
fdl's Avatar
fdl
Sounds like your wiring was done by a monkey. They probably sell cheap testers you can buy.
Old Jan 31, 2006 | 09:20 AM
Whiskers's Avatar
Go Giants
Possibly, it was done by the previous owner. Their last names were Kong....
Old Jan 31, 2006 | 09:30 AM
doopstr's Avatar
There is no need to get crazy over this. There is no wrong way to hook it up. The light bulb doesn't care. If you look at the light bulb socket it is flat, correct? It will let you stick the bulb in either way, there is no plus/minus.
Old Jan 31, 2006 | 09:34 AM
Whiskers's Avatar
Go Giants
This is true.
Old Apr 16, 2006 | 09:21 AM
Whiskers's Avatar
Go Giants
First nice weekend and it's done.....
Old Apr 16, 2006 | 10:41 AM
fsttyms1's Avatar
Old Apr 16, 2006 | 11:09 AM
Scrib's Avatar
post pics, FAWKER!
Old Apr 16, 2006 | 11:34 AM
Whiskers's Avatar
Go Giants
Old Apr 16, 2006 | 12:44 PM
doopstr's Avatar
See, I had faith that you wouldn't electrocute yourself. Too bad you won't be around to admire your own work.
Old Apr 16, 2006 | 01:06 PM
Whiskers's Avatar
Go Giants
Im trying to get the house in sellable / rentable condition.....Now if someone will come fix my friggin brick steps
Old Apr 17, 2006 | 07:30 AM
Scrib's Avatar
cute
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
