Gas Dryer Shutoff Valve
My nat gas dryer connects via flexible hose to a shutoff valve that is behind my washer. If I want to shutoff the gas it's a pain in the ass because I need to pull out the washer so that I can get to the valve. Can I put a shutoff valve directly onto my dryer and put the flexible hose into that? If not can I put a valve between two flexible hoses? Any other options? Move the copper pipe/valve closer to the dryer? Boom?
That's black gas pipe not copper.
Code in most states, if not all require the shutoff valve be on the incoming gas pipe not in flex or on the dryer.
Do you have a basement? Easiest solution would be to re-route the gas pipe from below to the correct location on that adjacent wall.
You could definitely do it yourself. You'll have to get measurements then go to HD or the like and have them cut and thread the pipe sections for you.
I don't have a basement under this room. Could I just run the pipe along the wall and secure it with brackets to the studs? The appearance wouldn't be import since the machines would hide the pipe.
For what reason would you need to shut off the gas line so often that you would move the valve location?
...other than when installing a new dryer/repairing the existing one?
