Garage Floor Coating
Hey all we are building a new house and I want to put some sort of coating on the garage floor. I want it to look nice and be easier to clean than the concrete. I've seen a lot of ads for this product, anybody ever used it?
http://www.ucoatit.com/main.htm
Received 1,080 Likes
Read all the warning about it. New concrete needs to cure for a while before you can coat it. You do the moisture test with the saran wrap taped to the floor. It's all about the prep.
Originally Posted by NSXNEXT
they make an excellent product. It is a bit expensive though.
It looks like it would be $400-500 for my 3 car garage, not too bad.
The sizzle in the Steak
I put this on my garage floor after I moved into my new house a few years back.
It's excellent, and no issues at all with it. Well worth it
Make sure whatever product you use, you follow the instructions VERY carefully.
http://rustoleum.com/CBGProduct.asp?pid=16
I'll check it out, how much was it and do you have some pics?
Depending on where you buy it, you need one box per (1) one car garage. So if you have a three car garage, you will need to purchase 3 kits.
Cost is about 50-70 bucks a kit depending on where you buy it.
Try Lowes or Home Depto.
The Creator
i was checking that stuff out at Lowes not too long ago, i believe it was $49.99 a kit.
what do you guys think works better? the stuff available from Lowes or the u-coat it stuff?
also, Rustoleum makes a "Professional" line as well, any pros/cons?
Peach Tea
My dad and I did this to our garage floor last year. It has held up extremely well and it's much easier to clean than the "carpet" we had in there before:
That looks great, which brand was it?
You can't go wrong with this stuff.
I will never have a plain conc. floor again. Epoxy coating FTW!
The Creator
I assume the stuff eventually wears down, what then? Do you just put down a fresh coat? Do you have to scrape it all up?
Are the "chips" anything but decorative? I'd prefer not to use them.
Peach Tea
Peach Tea
I would imagine that when it wears down you just put on a fresh coat. I could be wrong though.
It can be quite slick without them when the floor is wet.
FWIW is vacuum and then wet mop my garage floor...
I don't know how the floor would "wear down"....other than beating it to hell and chipping or cracking the epoxy resin coating. If you apply the coating per the instructions....and apply a generous (not thin) coating of material it should last for a very, very long time.
If the epoxy is coming off of the floor, my guess is it was applied incorrectly.
Either the conc. was not cleaned well enough, (this is a BIG part of the prep, and will make-or-break the job) or it was driven on before the floor had time to completely cure (I believe it was 5-7 days).
Yeah, it looks really nice. I've been wanting to get it for my garage too, just really haven't had time to get around to it.
Good thread...been thinking about this as my next to-do for the house.
Originally Posted by paz840
damn, the Rustoleum website says that the weather has to be higher than 60 degrees Fahrenheit during application and above 50 at night.
...i guess i'm not doing this until spring
:wink:
i did the epoxy coating on the garage floor as well....the only thing i have to complain about it is when it rains and you drive your car up into the garage, the water just drips and puddles there.
i think before i put the coating on...the water will just eventually seep into the concrete and go away...but with the epoxy coating...i have to squeegee (spelling?) the water out....and since i'm in seattle....fall/winter/spring sucks LOL
I just applied the U-Coat system with a friend to his garage. It was expensive but its a great product. ill be doing it to mine in the spring
MrHeeltoe
20
02-23-2023 01:54 PM
JDM96specCTR
10-17-2015 01:06 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
