BlackAck's House Projects Thread
#1601
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Also in May we had our basement rim joists insulated, there was little to no insulation in the basement and we desperately needed some, here's a few before and afters
There was some 1" fg insulation in some of the joists, but we had serious air leakage coming in all the way around, also the door had no insulation around the wood framing
A couple afters, we did spray foam all the way around the basement and it made a huge improvement
The following 2 users liked this post by 97BlackAckCL:
CCColtsicehockey (07-26-2023),
SamDoe1 (07-25-2023)
#1602
(Mid-Atlantic)
(Mid-Atlantic)
More house project updates, this project started back in April or May and has been going on for some time.... When we redid our deck, we opted to leave the joists and stair runners which were all painted. In hindsight we should have removed all given how bad the latex paint was on the deck overall. Here is a few befores of what was left to be removed which I've been working on here and there for months.
I spent hours stripping, scraping, and sanding the old paint as some adhered better than other, but it was difficult and extremely tedious and time consuming.
The stripper worked somewhat, but not great. Power tools did prove to work a bit better.
When stripping, I definitely put the scrapers through their paces and several of them ended up cracked or broken
We also pressure washed some of the harder to get paint with mixed results. In addition to sanding and prepping the wood, there also were a lot of old bolt and screw holes from the previous deck, so I filled all of those with wood putty and sanded.
You don't realize how many holes there are till you have them all filled lol
We also did a quick pressure wash on the decking to make sure it was clean and ready for stain. Here's a before
Given the gap between the boards we opted to use a brush in order to get down between the boards and to hit the top of the joists, I wanted to use rollers, but this definitely was the slower and more tedious way to do it
Coming along, almost halfway through first coat
Finishing up the first coat, working my way to the stairs
Final result of first coat, coverage was good, but I see why they recommend at least 2 coats
Some more of the first coat finished
We had my Daughter's 2nd bday here at the house, so I setup the grill. It was a hot and humid day!
00TL-P3.2 (07-26-2023)
#1603
(Mid-Atlantic)
(Mid-Atlantic)
Back at it, we started off getting the second coat down on the deck boards, the stain definitely covered and cured much better with the second coat and really sealed the wood decking on the second coat.
My wife came out and helped get the railing started
The next day we started by doing all the rest of the hand rails and stringers with the first coat, and then started on the long side of spindles
We managed to get the entire outside rail and all of the spindles done with the first coat, painting the spindles is extremally time consuming and tedious
I also did all of the handrails on the steps, and the right stringer since we had a few drops on that side.
And another look at the outer rail. Weather has been up and down so finding days to stain after 24 hrs no rain and 24 hrs no rain after for it to cure have been few and far between, but definitely making progress. More progress to come for sure
The following 3 users liked this post by 97BlackAckCL:
#1604
Looking good.
I had my water heater fail this year too and came out to a garage with water in it. Here is to hopefully 15 years+ for us both with the new ones.
97BlackAckCL (07-26-2023)
The following 2 users liked this post by SamDoe1:
97BlackAckCL (07-26-2023),
BreezyTL (07-31-2023)
97BlackAckCL (07-28-2023)
97BlackAckCL (07-31-2023)
00TL-P3.2 (08-02-2023),
CCColtsicehockey (08-07-2023)
97BlackAckCL (08-02-2023)
1StGenCL (08-03-2023)
1StGenCL (08-03-2023),
The following 2 users liked this post by 00TL-P3.2:
97BlackAckCL (08-03-2023),
civicdrivr (08-03-2023)
#1619
(Mid-Atlantic)
(Mid-Atlantic)
Got the stairs done today, also finished the underneath and the other stringer. Pain in the ass, but it's all stained. Fighting the weather the rest of the week
97BlackAckCL (08-04-2023)
#1622
(Mid-Atlantic)
(Mid-Atlantic)
Sadly the paint that was on the deck was peeling and so poorly applied that I had to remove anything that was loose or questionable, but I definitely questioned myself as I painted over certain painted parts lol
The following 4 users liked this post by SamDoe1:
1StGenCL (08-07-2023),
97BlackAckCL (08-04-2023),
CCColtsicehockey (08-07-2023),
rockstar143 (08-11-2023)
97BlackAckCL (08-07-2023)
The following 3 users liked this post by BreezyTL:
97BlackAckCL (08-08-2023),
thoiboi (08-14-2023)
#1633
(Mid-Atlantic)
(Mid-Atlantic)
That was my assumption as well
I don't hate ladders either, but the hill around the far side of the deck slopes in so many different ways it made it very precarious to be up that high
#1634
#1635
(Mid-Atlantic)
(Mid-Atlantic)
:pofl; Totally hear you, if it was in our budge we definitely would have done it. Sadly with a small child and paying for daycare we just couldn't swing it. More big house projects on the horizon though
97BlackAckCL (08-14-2023)
#1637
(Mid-Atlantic)
(Mid-Atlantic)
We had a few nice days without rain, so I was able to get all of the handrails and runners stained with their second coats. I also was able to do the second coat on the stairs, as well as the stair runners and the underneath of the stair treads. The only thing that doesn't have a second coat is the spindles, however that may wait until spring time given the amount of effort.
But the second coat really makes the stairs and everything look more finished and sealed. The wood actually looks like Trex decking now, which is great. Just hope it holds up.
The following 5 users liked this post by 97BlackAckCL:
00TL-P3.2 (08-28-2023),
1StGenCL (09-02-2023),
BreezyTL (08-29-2023),
CCColtsicehockey (08-28-2023),
civicdrivr (08-29-2023)
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Turbocoop
3G TL Photograph Gallery
23
05-01-2014 09:44 AM
