00TL-P3.2's New House
#361
Sadly, it went from having 4 vehicles in it, to 2.
#362
Spent the morning of New Year's day mending fences. I swear the builders in this neighborhood used the most garbage fence materials.
Replaced 2 posts (broken at ground level, rotted clean across) and 7 pickets (mostly dog damage there). In the last year or so, I've replaced 6 posts due to wood rot at the base. Multiple neighbors with similar issues, leaning fences or whole sections blowing over. On top of that, none of the pickets are consistent width; the majority are 5", but there are random 4.5" & 5.5" (which are about all you're able to find at HD). So I bought a stack of 5.5" & just rip off the extra width & re-dogear them at the top.
Having a pool, a proper secure fence is a priority for me.
New blade on the saw made a huge difference, old one was way far gone, to the point of needing 3 cuts to get through a 2x4.
Also got a creeper & shop stool for the garage for Christmas from the wife, and a new floor jack for my birthday from my parents.
Got a Raspberry Pi4 also, thinking about handing a spare TV in the garage & looking into a 3D printer.
The following 2 users liked this post by 00TL-P3.2:
CCColtsicehockey (01-04-2021),
civicdrivr (01-04-2021)
#364
Our Rinnai tankless water heater has been throwing a code 11 (no ignition) with increasing frequency.
Pretty much have to prop open the garage door (spring hinged) & cycle the 1/2 bath sink a few times until it ignites. ASSumption is corrosion/salt buildup on the ignitor.
#366
#367
No issues with any other gas appliances (stove/oven(s)/HVAC) & you can hear it trying to ignite. Guessing corroded/salted ingitor/flame rod.
But, I don't see any readily apparent method of opening the case.,
#368
Does it have a flame sensor? Often times that's what will fail or get dirty LONG before you get an actual ignitor failure. Should be fairly simple and easy to change if it is the problem. I clean mine off once a year to prevent issues.
#369
Not saying definitively that this is your problem, just sharing my experience
#370
Being Houston, I'd be surprised if we had seismic sensors on anything.
My boss' son is an HVAC guy, so going to try to have him take a look.
#372
Messy doesn't come close. So much drywall dust. Filled my 4gal shop vac with dust & drywall bits.
Still chopping up the scraps & filling our outside trash can. Just have 1 full-length piece of frame/baseboard to hack up & get rid of. Then just need to finish the touch up on the walls, been lazy & just don't want to deal with it right now
My brother-in-law does this stuff for a living, so I'll probably have him come over & do the touch-up & texture. I can manage the little bit of paint needed.
#373
Ordered a flame rod & ignitor kit for the water heater. For $26 it's worth a couple replacement parts.
#375
Put in the new flame rods & ignitor, and got nothing, even after multiple cycles it would not light.
Cleaned up the old ones, reinstalled them & it lit right up.
Noticed when I compared the ignitors, that the angle is different on them, so I think the new one just wasn't at the proper angle to ignite. At least I have spares now & back to on demand hot water.
#376
If it makes you feel any better ,same shit happened to with our old water heater heating elements...
bought a kit and swapped them (pretty sure it was the thermostat that was fucked)
accidentally ran it dry and melted one and when I looked at the old vs new side by side..
old one was a lot more robust!
#377
Well, if it ever goes out, I'll just have to try to match the proper angle of the ignitor based on the old one.
#379
Record lows in Houston.
Last time we got snow like this we didn't lose power.
Power went out at about 2am this morning, out for about an hour. Only stayed up for about 5 minutes & was back out around 3am. Had to go kill the breakers for the pool pumps so they don't try to activate when the power comes back on, they're frozen solid....
Hoping there's no damage to them when they thaw.
#381
Just plain out. 6 hours now.
#382
right, but there are various reasons for it.
sometimes it's a storm...heavy ice takes down lines etc...
other times the utility can't keep up with the kw demand as everyone cranks their heat and then it becomes a budget constraint.
they have to then decide on whether not they are going to recover from buying electricity from neighboring utilities at a much higher rate.
#383
I think it's a bit of both here. Some line damage & some load balancing.
#385
I bet you would
#387
Both ?
#389
Nope, still chillin (literally) at the in-law's place.
Probably go back to the house here in a bit to check on everything & let the dog out.
#390
Q('.')=O
We luckily haven't lost power yet. But half the people at work have and half my friends have... several times.
How far of a drive is the in laws? Also assume the roads aren't bad there? Our backup would be to drive to hers or my parents, about 20 miles away, but roads are awful.
#391
They live 5 miles from us. No highway.
Just got back from letting the dog out. Roads are worse than they were this morning, very slushy & a lot more people out. Lots of bad driving out there, but only saw 1 damaged car.
#392
You didn't bring the dog with you?
Do you guys have gas or electric for heat?
#393
Gas heat & appliances & fireplace. So we can cook (stovetop) & generate heat in the living room.
Gas tankless water heater, but no power to ignite.
Dog is ok at the house. Too cold for the kids, but she's content. I'll be going back over there to check on her & bring her back if we end up staying at the in-laws tonight. My in-laws have 3 dogs & adding an extra, plus our 3 kids is too much chaos.
#394
Posted in the weather thread.
Have a cracked brass ball valve for the sprinkler valve, looks like a straightforward replacement. Luckily were a ways off from needing the sprinklers.
More pressing is the cracked manifold on the pool heater. Have to get that replaced before I can turn the pumps on, no way to bypass the heater as is. Luckily, the replacement part is only about 5% the cost of replacing the whole heater.
No visible damage to any other pool components, so far. We'll see as things thaw. Looks like the pumps have freeze plugs & nothing looks out of sorts there.
Fingers crossed those are the only 2 freeze related issues we have to resolve.
#395
You have power back yet?
#396
>24 hours up so far.
Pool stuff still frozen, so no idea if there's further damage than the heater manifold.
#397
Received 3,841 Likes
Such crazy weather. So much further north than you guys and I never ever bother to winterize my sprinkler system. Hopefully, those are your only two freeze related issues.
#398
Parts should be coming in for the pool heater today. We'll see once I get it all up to pressure if there are any other leaks.
Luckily, Inyo Pools seems to have a pretty deep catalog of parts & reasonable pricing. Actually got recommended to them by a Leslie's employee, one of the reasons I like this particular Leslie's store. They don't push chemicals & actually try to save you some $$$.
#399
Parts are here.
Forecast shows rain for the next 5 days.
#400
Heater manifold replaced. Bit of a pain to do, but pretty straightforward.
Pump housing on the main filter pump is cracked The other 2 pumps appear to be fine & were running without issue..
Luckily, it's a replaceable part, now to order & wait; then hope nothing else is broken once I get things running & up to pressure.
