AASCO Flywheels put more power to the ground; Heeltoe Special Event Sale
Gain back your engine's lost power !
Drivetrain losses account for 15-25% of reduced power output. Energy is produced by the engine but is sapped by spinning accessories and other reciprocating parts of the engine. The flywheel is the largest mass on the engine that robs power. By installing a light-weight aluminum AASCO Motorsports flywheel, you can get much of that lost power back!
Gain in efficiency is the main benefit of installing an AASCO aluminum flywheel. Whether you are a street driver looking to reduce load on the enging and increase gas mileage, or a performance driver looking to increase your car's practical power output, AASCO flywheels fit the bill.
AASCO aluminum flywheels offer all the reduced weight possible and are strong enough to take all the abuse a street performance or road race driver can dish out. AASCO incorporates a replaceable friction surface that allows you to keep the same flywheel for the life of the car by simply replacing the steel friction disc when changing clutches.
- Low mass reduces drivetrain loss = MORE POWER
- Never replace or resurface your flywheel again!
- Lighter and longer lasting that chromoly.
- Tough enough for the rigors of GT3 racing.
- 100% DESIGNED AND MADE IN THE USA
Don't confuse 100% American made AASCO flywheels with other overseas-manufactured units. AASCO wheels are made with ANSI-certified 6061-T6 aluminum. With something as important as your flywheel, don't trust one billet material over another unless it carries the proper certification that only ANSI can provide.
Check it out our time sensitive group buy on Heeltoeauto.com!
Heeltoe Automotive : Promotions : GROUP BUY for AASCO Motorsports Billet Flywheels, all Honda/Acura applications - HeelToe Automotive
If you like this item, you might also be interested in:
Unorthodox Racing produces aluminum pulley kits that compliement the crankshaft weight savings offered by AASCO flywheels.
Heeltoe offers a wide range of clutch kits through our direct dirstributor sources: ACT, Exedy, Clutchmasters, Cusco, Carbonetics, and more! Email us if you don't see it on heeltoeauto.com!
When you pull out your transmission, you might as well change your transmission fluid as well! Order Honda Genuine MTF fluid change kit to get everything you need.
Thanks for checking out our post!
-HeeltoeAuto.com
Ok folks, after a few requests we have added some weights to the order page so you can see what the different wheels come in at!
http://www.heeltoeauto.com/product.php?productid=65853
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
