Upper Back and Hip Pain
What exercises do you feel the strain the most?
Having back injuries is serious, you may have turned your neck during an exercise which could be the cause, or you just need to lay off the weights and let your back recuperate.
Originally Posted by wsklar
Ive been concentrating on abs mostly. Right now basically:
Mostly abs, some arms and then cardio. I am not sure which one is causing the pain.
Pills or pads?
Pills or pads?
I was over-doing the push-ups and pulled something in my back as well. Got to see the DR about it.
Try some IBU-Profane first...if that don't help, try the hot/cold compress. Ice & heat pad back & forth.
Originally Posted by chef chris
Are you doing sit-ups, push-ups...? Sit-ups can fvck your back/neck up easily.
Pills or pads?
Pills or pads?
What specific exercises are you doing?
rockyboy
08-04-2024 10:35 AM
cycdaniel
12-17-2019 10:58 AM
