Sharp pain in elbow.
Moderator Alumnus
So i have been lifting pretty heavily for the last 10 months. Over the weekend i developed a very sharp pain in my left elbow. The pain is on the upper outer part of my elbow, sort of under the "ball" of muscle you can get if you flex your arms.
Any ideas as to what this is? I'm hearing all different things, tendinitis, etc.
It only hurts when i start to go past a 90 degree angle with my arm. It is very sharp and hurts a LOT. And i have a pretty high threshold for pain...
TIA!
TIA!
You may have hyper extended it, or excessive lifting has finally caught up and you need to take some down time and rest the elbow.
You may have tweaked it lifting and not noticed until the pain really kicked in.
Ice it, rest it, and if the pain does not go away, see a doctor.
Moderator Alumnus
Team Camel, VP for Zaino
Did you notice it happening during or right after a particular lift? If you can isolate the move that caused the pain, you can better understand what's going on, and how to avoid it in the future.
If you injured yourself on a "pulling" exercise like rows or pull ups, then it's probably tendonitis which will suck (I know based on personal experience) because that can take a long time to heal. If it is tendonitis, then you're probably not resting enough - especially if you're going heavy. Once you're feeling better, you should work in a week off every 3-6 weeks so that your tendons can catch up with what your muscles are capable of.
If you injured yourself doing a "push", then I'm not sure what you did - but may want to consider seeing a doc.
^ agreed.
my guess based on your description is tendonitis. try taking about 400mg of ibuprofen and see if it takes the edge off the pain or if the pain even goes away. tendonitis in elbows and shoulders are a very common injury with (heavy) pulling excercises. the only way to treat tendonitis is absolute rest for about 2-4 weeks, and get back into it slowly.
Moderator Alumnus
Thanks guys, I'm not too sure how it happened it kinda just crept up on me this weekend, and i dont even lift on the weekends.
It only hurts when i extend it past a certain point (nowhere near hyper). Other than that nothing hurts i can push and pull, as long as my arm doesn't straighten out past a certain point.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Same thing is happening to my knee since I started walking 3-4 miles a day, try stretching more as well as giving it the weeks rest.
(Mid-Atlantic)
(Mid-Atlantic)
Yes, what I meant was give it the rest, but before lifting, try stretching it more
Moderator Alumnus
Bringing Home The Bacon
If you've been lifting heavy, it might be a form issue. Are you doing any lifts with arms locked out (front raises/lateral raises/chest flies etc)? Those put a ton of stress on the elbow joint...I've definitely had a flare or two, but I've been pretty careful about keeping a slight bend lately.
rockyboy
12-06-2022 02:29 PM
AcuraKidd
09-26-2015 04:10 PM
