Forearm pain
I
Forearm pain
Every time I train biceps and do curls my right forearm starts hurting. It gets to the point where I know I can do more sets as far as bicep strength goes, but the right forearm just hurts too much. I've heard of a lot of people having this problem and it's nothing unusual, but theirs seems to go away. Mine has been hurting for months, even after taking a week or two off. Is there a forearm brace for this type of pain? It sucks not being able to do a full workout because of it. Sometimes it hurts even when I'm not doing curls. There is little pain in the left one, but nearly not as much as the right.
Originally Posted by FastAcura
I have been using the easycurl. I just tried using straight barbell a couple of days ago and it actually feels better. Dumbells work best.
Moderator Alumnus
i know exactly what your talking about, that shit hurts like crazy, and its not just when i curl its when i grip anything tightly, like moving a table for instance, or just picking up the bar, its been happening for quite some time now and it feels as if it is getting worse, help!
I
Yes, exactly. Just putting weights onto the bar makes it painful. If it's bad form, shouldn't both arms hurt since I do with one what I do with the other?
I
Originally Posted by ABreece
Are you curling your wrist up when you lift the bar? THat's a good way to cause yourself pain, especially once you get to the top of the rep and the bar actually pulls down and towards you, if you know what i'm talking about. I used to do it.
I
It feels like the bone. I should mention that I was in a car accident a few weeks ago and hurt that exact spot. My arm was hurting from my finger all the way to my shoulder, but that went away after a day or two.
![Captain Obvious](https://acurazine.com/forums/images/smilies/captainobvious.gif)
Maybe you have a bone density problem (there is a test for this), or a hairline fracture (or something like shin splints, but in your forearm bone).
If the bone is damaged you may need a couple months to let it heal. Then perhaps do higher reps and less weight.
I
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
The forearm was hurting before the accident. It got hit a little during the accident, but not much. It feels the same way it did before. It didn't just appear after the accident.
ok, well see my previous post.
That's Racist
I was told that when your forearm muscle develops, it gets bigger and can end up pinching the nerves in your forearm... that's where the pain comes from . Is that true?
Moderator Alumnus
That's Racist
Originally Posted by FiftyFive
i think thats whats happening to me, my forearm gets really tight and hurts a fucking lot, no accidents here, it feels exactly like hin splints in my forearm whenever lifting weight
Does it go like this? When you're on the preacher curl, you'll curl up, and the pain is either not there or less evident, when you go down, you feel the pain, and then when you let all tension go and let go of the weight, the pain is insane, right?
I
I get the same thing, but I don't think it's as severe as yours...
That's Racist
From what I've been told, apparently, that pain will just go away with time... how long have you guys had this pain, how long have you been lifting, and how long has your longest consistent lifting cycle been... have you guys been taking any time off from lifting and such?
I had a really hard time with this pain a couple of summers ago when i was lifting 5-6 days a week and working @ souplantation (as a busser) like, 4-5 nights a week. I would hold trays stacked with plates that were about 60-70 pounds, and I would feel the most stress and pain after I had carried it all back to the kitchen and set it down.
I do biceps once a week and only get this pain a little bit now. Im not sure what I did differnetly, but I did stop lifting for a good chunk of time this previous academic year (like, a month or two off).
Edit: I don't know if you have to go far enough to get some sort of scan to see if your forearm bone has any compound fractures or anything...
The Third Ball
Received 4,917 Likes
It sounds like it might be tennis elbow. go to rite aid, cvs, etc and get a tennis elbow strap. wear it and see if that helps.
Wants an M3 in
suppination ... "suppinate your palms"
my buddies and me have all experienced this when your muscles become stronger at a faster rate then your bones. Just give it time to catch up. Lay off preachers for awhile or just stick it out and it will eventually go away. Try to do single dumbell exercises and nothing that has to do with curling a bar. One thing that helps is when you set the bar back down on the rest (usually where most people experience the most pain) keep your palms facing up and release your hands open. This seems to lessen the pain for most people.
btw usually when someone does a cycle or starts using creatine and they gain a little bit of strength too quickly this seems to always happen. Just keep in mind when you lift weights that your bones are also getting stronger just alot slower.
That's Racist
That's what I'm thinking as well. I haven't had a problem with this for awhile, and I've only been told really to work through it, or lay off the high intensity lifting for awhile.
rockyboy
12-06-2022 02:29 PM
AcuraKidd
09-26-2015 04:10 PM
pistacio
09-26-2015 09:45 AM
