For the cyclists
For the cyclists
For anyone that rides a trainer when the weather is bad or early in the morning before work.
Anyone who has ever used rollers knows that you can only sit and ride but not anymore.
Take a look at these rollers.
http://www.rockingrollers.com
They are sick, I tried them out at my local bike shop and am now looking to get a set, you cannot fall off them like conventional rollers. You just bang into the side bumpers which keep you on. You can stand and sprint or try standing simulate climbing a steep hill.
The only drawback is they are not cheap. $800.
Hmmm ... looks interesting. The only drawback to this over a trainer is space. Rollers just take up so much room. Luckily, the winters aren't too long here, and it only rains, so I can still ride. I'll have to check my local shop to see if I can try them out.
Originally Posted by Whiskers
Any cheaper way to ride a real bike indoors?
Rollers take a little skill and practice. You will ride off the side while you are learning to use them, but you do not do the wile e. coyote and take off. You just loose all that was keeping you upright (centripical force from the wheels) and tip over.
rear wheel trainers are good. two main types are fluid and magnetic. the fluid ones are smoother and therefore more expensive. you should be able to find one for around 200-300. magnetic ones go for around 100.
rockyboy
Aug 4, 2024 10:35 AM
