Barbell squats vs. Dumbbell squats?
That's Racist
I know the answer is benefits of barbell squats > dumbbell squats.
I was just wondering if anyone could explain the reasoning behind it. I've tried both, and for some reason prefer the dumbbells
Also, is there a differnece in benefits between front and rear barbell squats?
Moderator Alumnus
ALL free weight exercises are better with barbells if your ultimate goal is ultimate overload and/or ultimate muscle growth and strength.
The reason behind it is that barbells will help you lift more weight than dumbells because of many reasons. The main reason is balance. If you can balance the weight you are lifting better, you will lift more total weight. Another reason is, any differences in strength in left or right limbs is not as much of a factor with a bar.
Front squats put a lot more strain on your legs than your back. Also because it's harder to balance with front squats they are less of an overload exercise than back squats are.
That's Racist
Originally Posted by gavriil
Yes I can explain it and yes there is a difference between front and back squats.
Moderator Alumnus
I think doing both front and back squats the same day is probably overkill. If you want to do them, do them after back squats and only 2-3 sets of which 2 of 3 would be acclimation sets.
That's Racist
Hey Gav,
Is it safe to say that in this way, the dumb-bells (granted that my weight limit is the same for both dumb-bell and barbell) are better for training stabilizer muscles that otherwise wouldn't get affected as much by barbell squats?
(like bench press vs. dumb-bell press benefits?)
Moderator Alumnus
Hey Gav,
Acutally the opposite. Stabilizer muscles will get more overloaded with the bar due to less balance issues. Dumbells are always more of an isolation exercise than the bar.
DiamondJoeQuimby
09-10-2015 11:40 AM
advantages, barbell, club, difference, dumbbell, dumbell, gardening, harder, home, life, membership, national, powered, squats, vbulletin
