Trip meter resets itself
So I have been having this issue with my car since day one. I have set my trip meter to reset to zero when I fill the tank. I like to see how many kms I get out of a tank. The problem is, the trip meter automatically resets to zero once the tank is 3/4, so I never get to see how many kms I would get in a tank using trip meter A, trip meter B however works fine and that's what I use for my calculations.
Anyone with the same issue? |
That is by design - I believe you can change that setting in the menu options (when the car in in park).
Alternatively - you can check your km/gallon before you fill up. |
Originally Posted by Pete2010
(Post 13926919)
Originally Posted by MyBlackBeauty
(Post 13926831)
Anyone with the same issue? Go to your setting and disable that feature. I think yours is set to reset the trip A when you fill up the gas. |
Originally Posted by sojue
(Post 13927042)
This happened to me too once. Under personal setting menu, I set to reset Trip A every time I refuel the gas. However, the trip A reset itself even though I did not fill the gas. So I just disabled that feature and I just mannually reset it once I fill the gas.
Originally Posted by Mr Marco
(Post 13927176)
(Post 13927057)
I know that option is ON and I want it that way and it should work fine and if it doesn't, they should fix it. Why should I try to find work arounds? It's not a cheap car!
(Post 13927057)
Originally Posted by KPSBUDS420
(Post 13928072)
I have different issues with my car, but feel the same dude... Give em hell! Why should I have to listen to a spooling whine from 15-50mph ( which is 90% of my driving) when other tl's don't make that noise. Just cause they can't pinpoint it don't mean squat.. Fix my 40k NEW car.
I have seen the same issue with the auto reset but, not at the same intervals.
Mine does this periodically for no particular reason.
Originally Posted by BLEXV6
(Post 13928137)
Mine was doing something similar.
https://acurazine.com/forums/4g-tl-problems-fixes-297/trip-odometer-avg-mileage-ipod-automatically-resetting-858244/ |
Could it be that you are pressing the fuel cap button instead of the trunk release at one point? This would cause your trip meter to reset.
Originally Posted by mdxsilversurfer
(Post 13928662)
Originally Posted by Hogan9166
(Post 13928100)
It has happened to me 4 times now. Three times, including this morning, it happened at a gas station where I fill up about 80% of the time, but I had just gone into the store for something and didn't gas up. The other time it happened was when I went into the store of a gas station that I had filled up at several times the weeks prior to that. I know this is an odd question, but it isn't tied to the GPS location somehow, is it? It has never reset while driving, but always after shutting the car off and restarting at a gas station where I have filled up several times previously. Weird. |
(Post 13927894)
I am, DUDE! but I wanted to know if others have noticed the same issue.
(Post 13928072)
Can't be that because it happened to me while driving.
(Post 13929189)
So, it just happened to me again this morning. As I said above, it doesn't happen at consistent gas levels, but what I have noticed may be a coincidence, but it is a little odd if it is.
(Post 13929338)
Sorry for the thread revival, but I am having the same problem. Trip A is set to reset when I fuel, and it does, but then it resets itself again before I even fuel the next time. Most of the time I'm just fueling up half tank. Anyone found a fix for this yet? Is there even a fix at all ?
Originally Posted by Nev05
(Post 16370526)
I have trip A set to reset when refueling. It will do that whether or not I actually fill the tank. AFAIK this is normal. Refueling != filling up. Note that it doesn't actually reset until the car moves after fueling.
