Sponsored by: DashLynx
PCM/TPS reset help
Old 02-19-2018, 09:57 AM
4th Gear
Caybren Marez's Avatar
PCM/TPS reset help
So I sprayed throttle body cleaner in my 09 TL. Didn’t open the flaps on it just sprayed and wiped it off with a rag. I’m not getting a off idle and getting a check engine light. From what I’ve read I need to reset my tps and pcm. My local acura dealer will do it for $150, but I wanted to see if this is something I can do on my own. I’ve looked up how to’s but I’m getting a lot of different information (unplugging battery, pulling fuse, using a scanner).
Help wiuld be appreciated. Thanks!
RKeatF1
03-26-2010 10:19 PM
spinxt
03-15-2009 09:06 PM
Quick Reply: PCM/TPS reset help
