Make fog lights turn on with "parking lights"
Hey AZners...
Pardon if this topic been discussed... also, my english is not great but let me try to explain.
I wanted to make my 4G TL fog lights turn on with "corner lights/parking", while headlights off, even bought HID kit. Visited my friend who's doing anything what relates to electric portion for any car model. After 20 mins doing research and trying different things, he said it's impossible since everything being controlled by brain/main computer. However, he mentioned maybe do-able if extra relays + bunch of wiring ran. A little upset but want to know if someone has done similar.
FYI... I have done the same on my 2G & 3G TL's....
Thanks in advance
Thanks in advance
it can be done, just use relay and wire it independently with a switch.. i have seen it done before but have not seen it done where it would turn on with the oem headlight switch.
just wire it independently.
shurik74 (04-27-2014)
The Original Shawdy
Couldn't you run it like pots mentioned and then tap into the corners for it to come on with your parking lights?
you can make your own harness to run independent of the OEM fog wiring which comes with a switch, and you can wire it to a hot fuse inside the car near the driver foot well fuse box.
I plan to fix mine to have this capability so I dont have to keep remembering to turn off the lights.
superbrightleds.com sells a wiring harness with relay.
Thank you guys for all feedback and recommendations. I'm not good with electrical portion, had bad experience fixing house wiring I do mechanical & body fix only
Plan is to go back to my electrician with info from you
2011 SH-AWD 6MT
Why is it important to have it on an independent switch when the fog lights are already switched? I've wired previous cars' fog lights to the running lights and I don't see why we can't with the TL.
Angel UA8 (04-29-2014)
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
