Sponsored by: DashLynx
How to change the bulb in the sidemarker?
Old 11-06-2010, 06:47 PM
grkbadboy7's Avatar
i have been reading the threads for changing the whole unit. however i want to know how you can change the bulb? do you need to do the same process? or do you snap them in and out?
step by step instructions will be appreciated
Old 11-06-2010, 06:58 PM
Pete2010's Avatar
Check your owners manual - it's much easier than you think.
Basically, the easiest way is to turn your wheel to the right so that the driver side tire is pointed inward. Unscrew and pop out the snaps holding in the wheel well. Peel that back, and you can stick your arm in to reach the side marker. Twist the back of the electrical contact going to the sidemarker and pull it towards you.
Then, just pull out the old bulb and pop in the new one. I changed mine to orange led's and it only took a couple of minutes.
Old 11-06-2010, 07:52 PM
grkbadboy7's Avatar
thanks.. first thing tomorrow morning ill try it out
pplcrew
01-30-2021 08:59 AM
BoricuaTL
04-08-2016 01:08 PM
Silverstead1
09-17-2015 06:45 AM
acuraST
09-17-2015 02:31 AM
Aleax
09-11-2015 11:31 AM
Quick Reply: How to change the bulb in the sidemarker?
