Sponsored by: DashLynx
HL22-1200 Lumen V-LEDS
Old 04-04-2013, 08:40 AM
  #81
HeartTLs's Avatar
Originally Posted by KB1Spec
Do it tonight
Where my pics?!
Old 04-04-2013, 08:49 AM
  #82
TeamAcura's Avatar
Originally Posted by HeartTLs
Where my pics?!
LOL
Old 04-04-2013, 08:52 AM
  #83
CamPhil's Avatar
Where my pics?!
Originally Posted by TeamAcura
LOL
haha... the natives are getting restless!
KB, did you have to modify anything to make the bulbs fit since they have such massive heat sinks.
Old 04-04-2013, 10:59 AM
  #84
KB1Spec's Avatar
No pic last night. My friend borrowed my car to pick up his mom at the airport. I'll try to get my car back today and do it if I can.
Old 04-04-2013, 11:00 AM
  #85
KB1Spec's Avatar
There was space on the passenger side but on the driver side it fit nicely tight.
CamPhil (04-04-2013)
Old 04-05-2013, 09:33 PM
  #86
CamPhil's Avatar
Got the lights in today but not having much luck installing them. I have no idea how you got the bulbs in. When I tried, the heat sink hits the underside of the frame that the headlights bolt to.
HELP!!!
Old 04-06-2013, 03:02 AM
  #87
potmilkz's Avatar
Received 1,020 Likes on 792 Posts
have you tried calling jlc?
Old 04-06-2013, 12:20 PM
  #88
CamPhil's Avatar
I left a VM for them...hope they get back to me soon. There is space from front to back, but the issue is that damn heat sink. It flares out at the end.
Old 04-06-2013, 01:26 PM
  #89
2012 TL SH-AWD
Zelaya's Avatar
So JLC have the new one available??
Old 04-08-2013, 08:48 AM
  #90
CamPhil's Avatar
Yeah, it is available for sale. I'm still waiting to hear back from JLC to see if there is anything special I need to do to make it fit. I have no idea how KB1 was able to seat it correctly in the reflector housing. Even if I take the bumper off and remove the headlight housing to install bulbs, I don't foresee being able to put it all back together AND not have the heat sink hit the underside of the car's frame.
Old 04-08-2013, 08:58 AM
  #91
TeamAcura's Avatar
If you're up for it, you could dremel or shave the heat sink down so that it can fit. I bit of improvising\modifiying but if you plan not returning the bulbs it's worth a shot. GL either way and I'm sure you'll keep everyone posted.
Old 04-08-2013, 09:09 AM
  #92
CamPhil's Avatar
I don't disagree and certainly don't mind having to "massage" it a little so it'll fit, but my expectations were that they would fit without the need to mod since JLC did not indicate otherwise. Just waiting to hear back and see how they got it work work in KB1's car since he did not need to modify anything to make it fit. JLC also charges a hefty 25% restocking fee on returned items so its almost not worth sending it back. If they are not able to offer suggestions then they should at the very least update their site and put up a disclaimer about the possibility of having to modify the item for future reference to other possible customers.
I hooked up the lights to make sure they worked and the output looks promising. Its just a shame that I might have to cut into the heat sink to make it work. I'm also a little concerned that this may effect the overall performance and not allow heat to dissipate appropriately.
Old 04-08-2013, 09:42 AM
  #93
2012 TL SH-AWD
Zelaya's Avatar
I remebered when I got my 9005 from JLC the bulb didn't fit the housing and they had to send me another type with a slimmer bulb tip. Hopefully you can resolve before I order mine. Can you take pic of the bulb so we can have a better understanding.
Old 04-08-2013, 09:53 AM
  #94
CamPhil's Avatar
I don't think that same scenario applies here. Depending on your application, they will send you adapter to fit the factory harness. The acutal bulb and heat sink can't be swapped out. Not sure what pictures I can send you to show the issue more clearly because it would be hard to get a camera into the engine bay behind and under the frame. I'll give it a try tonight but no promises.
Old 04-09-2013, 11:37 AM
  #95
CamPhil's Avatar
I Contacted JLC and they couldn't offer any other solution. Rather annoying, but I spent another couple of hours trying to get these to sit correctly in the housing with no luck.
I'm going to have to shave down the ends, but luckily I discovered that the heat sink can be unscrewed.
Just a warning to anybody interested in these... just be aware that you might run into the same fitment issues. Hopefully, you'll have better luck and not need to modify.
Old 04-09-2013, 01:01 PM
  #96
deuce415's Avatar
They put some huge LEDs on there! I can see why it would need big heat sinks.
Old 04-09-2013, 01:11 PM
  #97
potmilkz's Avatar
so wheres the shaving pics?
Old 04-09-2013, 01:14 PM
  #98
CamPhil's Avatar
Didn't have time to cut back any of the heat sink yet. Plan on taking a dremel to it with a metal cutting wheel and I'll post more pictures when I get to it later this week.
Old 04-11-2013, 10:20 AM
  #99
HeartTLs's Avatar
way too labor intensive for an already expensive product. JLC, get back to me when it fits properly.
Old 04-15-2013, 08:39 AM
  #100
CamPhil's Avatar
You're not kidding...I spent an hour or so with the dremel and metal cutting wheel, but since the wheel's diameter is too small couldn't cut all the way through. If I had a bigger cutting wheel, it wouldn't have been an issue. I put it on hold until I could get my hands on a reciprocating saw which I'm hoping can help finish the job.
I wonder if anybody else would run into the same issues. When I spoke to JLC, they said that it took them a good amount of time to get it to fit into KB1's car and they just had to "play around with it".
Old 04-15-2013, 03:41 PM
  #101
jdm_fanatix's Avatar
wow what front lip is that? looks awsome
Old 04-18-2013, 08:16 AM
  #102
2012 TL SH-AWD
Zelaya's Avatar
I agreed with HeartTLs makes no sense paying premium money for something you have to modify, now leaving that on a side how's the light output.
Old 04-18-2013, 09:15 AM
  #103
RSLTSX09XMNAVWX's Avatar
Lets see how it turns out
Interesting post, will see how he makes them fit..
Old 04-18-2013, 10:52 AM
  #104
keith7120's Avatar
The HL22-1200 Lumen V-LEDS works just fine. I was hoping to see pics of the completely installed JLC product in the TL just to get a comparison. That huge heat sink is ridiculous.
Old 04-19-2013, 12:56 PM
  #105
CamPhil's Avatar
Sorry...I've had a bunch of other activities take up my time recently, but I did get a hold of a reciprocating saw. Hope to have the heat sink trimmed and lights installed by the middle of next week. Will keep everybody posted.
Old 04-19-2013, 01:22 PM
  #106
6G TLX-S
Edward'TLS's Avatar
Received 1,136 Likes on 814 Posts
If you trim down the giant heat sink, will it not be sufficient enough to cool down the super-hot LED's ?
Old 04-19-2013, 01:31 PM
  #107
CamPhil's Avatar
Only one way for me to find out. I plan on running it at different intervals and log how hot it gets. I've seen similar heat sinks online through Chinese distributors which I think may fit the existing thread pattern. Who knows, maybe down the road they will update the current heat sink so it won't cause any clearance issues.
Old 04-19-2013, 01:49 PM
  #108
6G TLX-S
Edward'TLS's Avatar
That's a lot of work trying to mickey-mouse in a not-designed-to-fit LED bulb.
But nice work, and we all appreciate your valuable effort and contribution to the knowledge pool in Acurazine.
Old 05-07-2013, 02:28 PM
  #109
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
just did it on my car:
Old 05-08-2013, 01:47 AM
  #110
KB LADHAR
LADHAR's Avatar
Try headlightbulbs.com
I ordered 2 sets one for fog one for drl
Total $60 including shipping to canada I will post pics as soon i get them
Old 05-15-2013, 10:58 AM
  #111
HeartTLs's Avatar
Camphil any updates? Paperboy you had to remove the headlight from the bumper to make it work? Did you have any problems with putting the headlight back in with the led installed?
Old 05-15-2013, 01:40 PM
  #112
CamPhil's Avatar
Sorry guys, been MIA dealing with stuff and haven't had a chance to play around with the lights. I'm finally back home and will be around for the next 2 weeks so should have something updated to show you guys.
Old 05-15-2013, 03:50 PM
  #113
HeartTLs's Avatar
Hope you're alright, in for pics!
Old 09-27-2013, 12:55 PM
  #114
3rd Gear
BigManny's Avatar
v2 Option
as anybody tried these from iJDMToy? These appear to be a new version with a much smaller heatsink. The guy at iJDM did not seem to think that these would also need resistors, but I do't necessarily believe that.
http://store.ijdmtoy.com/High-Power-...headlights.htm
Extremely Bright HID Equivalent 6000K OEM Xenon White 20W High Power H8 H11 9005 9006 LED Bulbs Upgrading Kit For Headlights or Fog Lights.
Old 09-27-2013, 01:06 PM
  #115
potmilkz's Avatar
yea its 140 bucks tho.
Old 09-27-2013, 02:31 PM
  #116
Mr Marco's Avatar
My guess is that, like most engineered components, it's twice as big as it needs to be.
Old 10-04-2013, 02:19 PM
  #117
DeeQRL's Avatar
JLC's V2
they will get new shipment on 9005,h7 & h11 soon.
P.S: this LED is 4 sides output compare to ijdmtoy's 2 sides
Old 10-04-2013, 07:04 PM
  #118
3rd Gear
BigManny's Avatar
I tried the the V2 like the one from ijdm and had one with a bad solder. I thought no big dig deal and tried to remove them from the vehicle. Easier said then done. When you try to remove the bulb the heatsink spins off of the base. I took well over an hour and a ton of brute force to get them off. Just a heads up.
I like the looks of the JLC version, but hope that they do not have the same removal issue with the heatsink. Also, the v2 from iJDM did not require the resistor.
Mike
Old 10-17-2013, 11:23 PM
  #119
merak's Avatar
I installed these tonight. DRLs work perfectly, without flicker and without setting the DRL light on the dash.
High beams are damn bright.
Old 06-05-2014, 10:30 AM
  #120
deuce415's Avatar
I was poking around VLED's site and noticed that they have an updated version of the CREE MT-G2 with bulbs on both sides now. It's $200, which is out of my price range for DRL bulbs. Just thought I'd throw this into this thread for those that are still looking for DRL LED bulbs.
http://www.vleds.com/bulb-type/dayti...g2-3000lm.html
It says it is rated at 3000 lumens, which is real close to HID output.
Quick Reply: HL22-1200 Lumen V-LEDS
