Difference between Honda and Acura parts?
Like soniczoom5, one of my turn signals light assembly got cracked by a rock (hopefully), instead of being shot at while on I-290. ;-) The part I am looking for is 33350-TK4-A11. Via Google, I came across HPU's site, and the same part number for Honda (also a left front turn light assembly) costs $35.46, while the Acura counterpart with the same description costs $55.32. Knowing how Honda and Acura share lots of parts, do you think this turn light assembly is interchangeable between Honda and Acura?
same part number = same part.
Even if it doesn't, it's a 2 dollar bulb
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
The only Acura parts that I'm aware of is fluids. You put an "a" on the end of the part number and it has an Acura label. Other than that, they're all Honda parts.
Reorge (11-10-2016)
Something I will add, in some instances you're not able to order the part via Honda if it's an Acura part number. Even if they're identical. I've found that some of the websites list the prices and must have some formula to calculate the price.
The turn signal assembly is not used in any Honda vehicle and is specific to the TL. So you could try to order it but my assumption is it will be cancelled.
Reorge (11-10-2016)
Since their shipping is more than HondaPartsNow, I bought it from the latter site. Let's see if my order gets canceled.
This is interesting, because I finally tried to order it from HondaPartsUnlimited. They sell the same part number for both Honda ($35.46) and Acura ($55.32). If I place the Honda part in my cart first, followed by the Acura part, both parts in my cart come out to $55.32 each. But if I clear out my cart and reverse the order, both parts in my cart come out to $35.46 each. But I don't need two of them, so I remove the Honda part in the hopes that I can get the Acura part for $35.46. Nope. The cart updates the price of the Acura part to $55.32. LOL
I know for sure as Reorge said, you can buy trans fluid (ATF) cheaper from Honda and it's the same stuff used in a TL.
I would not use alternate brand ATF in an Acura though, although many folks on here seem to believe in doing so.
fury
06-27-2016 06:48 PM
