DEAL/front bulbs upgrade
Old 01-11-2017, 10:13 PM
toferdisobey
Christopher Michael's Avatar
Hi guys, I'm new to Acura ownership I found a great deal on a 2009 TL with only 50,000 miles. Reliability for that year seems outstanding so I jumped on the offer. I want to upgrade the DRLs. But I also see guys talking about shutting them off all together. What is everyone's opinion on this?
If you vote to keep them and upgrade, are these good choices?
http://www.vleds.com/shop-application/application-high-beam/9005-hb3/9005-ultra-lmz.html
http://store.ijdmtoy.com/9005-CREE-High-Beam-LED-Daytime-Lights-Kit-p/40-070-drl.htm
If you vote to remove them, I guess just pulling the fuse and I won't see any error messages?
Second question, anybody have opinions on which led bulbs to use for the front turn signals?
Thanks in advance!
Old 01-19-2017, 09:44 AM
umber1's Avatar
Either one will do. Just an fyi, more than likely you will get a "Check DRL Lights" on the dash
Old 01-19-2017, 09:46 AM
Received 8,693 Likes on 6,707 Posts
There are multiple threads here: https://www.google.com/search?q=site...hrome&ie=UTF-8
Read through them and see which one best fits your wants/needs/style!
Old 01-19-2017, 12:12 PM
toferdisobey
I decided
Thanks guys. I decided to go with the V3 Triton's for the blinkers. And then an HID kit for the high beam DRL. I think spending more money on a better set up is the best choice. Plus, with these kits it's all plug and play. No splicing because even the resistors are connected via plug n play.
Old 01-19-2017, 12:20 PM
Great choice!
toferdisobey
I meant LED kit. And all are from www.vleds.com
Old 02-06-2017, 03:37 AM
toferdisobey
I have ordered all the LEDs and will post photos/video link when they are installed. The V3s are on back order so I should get them by next month they said.
Old 02-06-2017, 10:01 PM
Blaze9's Avatar
I have a standard SMD flashback, cost me 25 bucks. What's the difference between the SMD ones and the 200 dollar tritons?
Old 02-06-2017, 10:14 PM
toferdisobey
The V3S Triton's are the professional way to do an LED upgrade. The plug and play means no wire splicing when you have an on board computer monitoring the draw of current. Others require you to splice in a resistor. They are also better than a regular LED bulb because the lumens is much better in bright sunlight versus the cheaper bulbs. Hope that helps.
Old 02-06-2017, 10:36 PM
Blaze9's Avatar
I opted to skip the resistor regardless, and from what I can tell the brightness is pretty good still on mine. I'll take a few pics and post it.
Old 02-06-2017, 11:11 PM
toferdisobey
Cool yes please share your photos. Take them in the sunlight to show it since that's the most important. Also, you don't get a bulb out warning?
Old 02-07-2017, 06:42 PM
Blaze9's Avatar
You hyperflash, no warning light or anything in the infotainment system. Just the hyper flashing. However I personally like how that sounds and looks so I opted to stick with that. The hazard lights switch will make them flash at a steady rate, just the turn signal will make them hyper flash.
I'll take a pic tomorrow and tomorrow night to give you an idea.
Old 02-15-2017, 02:57 PM
Blaze9's Avatar
Well I guess it's finally tomorrow. My bad bud.
Here's some day-shots with headlights on and fogs on and off. I'll get some night shots soon.
Imgur: The most awesome images on the Internet
Old 02-15-2017, 03:06 PM
toferdisobey
Hey they look pretty good man. Mine should arrive early March they said, so I'll post my pics after install.
Old 02-16-2017, 02:14 AM
Soal Man's Avatar
Sucks that your stuff is on backorder. Looking fwd to see your progress in March.
Old 02-27-2017, 06:33 PM
toferdisobey
Alright so the DRLs arrived yesterday and I installed them. Part one of my light project. Took me about 10mins and they are perfect. For anyone still looking and not knowing, these from vleds are perfect and the best thing is they put out the proper amount of power, so no resistors needed and the computer does not throw a DRL code. Plug n play install. You can buy them here: http://www.vleds.com/shop-application/application-high-beam/9005-hb3/smz-9005.html
Soal Man (03-02-2017)
Old 02-27-2017, 08:51 PM
Keeping TL until 2029
echodigital's Avatar
Thanks for the update! I was thinking about this post as well. I hate the yellow DRLs.
Old 02-28-2017, 04:37 PM
PR_TL's Avatar
VLED's is the way to go! The yellow DRL are blah
Old 02-28-2017, 08:00 PM
Blaze9's Avatar
How are the low vs high beams? The DRL light does both DRL and highbeams correct? AFAIK most LED highbeams are pretty bad. Can you give us a night-time shot?
Old 02-28-2017, 08:18 PM
toferdisobey
Your low beams are HID. The stock high beams are halogen. The DRLs are only the high beams, just at a lower power setting, so not 100% until you actually activate high beams. The DRL LEDs I speak about above are perfect. You won't be disappointed. Considering the usage or DRLs to high beams, the DRLs were more important. They're simply used more of the time than any other light, except your low beams...
Old 02-28-2017, 08:21 PM
toferdisobey
Will take a photo for you tomorrow.
Old 02-28-2017, 11:11 PM
Blaze9's Avatar
Yeah, that's why I was wondering how the low vs high beams compare. I almost never run DRLs, my car usually is always on low-beams. I might get a nice set of LED DRLs if I can actually use the high-beams. I do go into woody/forested areas at night at my drive home roughly 2x a week so I often use high-beams to see better. I wouldn't be able to trade a lower lumen/throw high beam for a nicer looking DRL.
Old 03-01-2017, 12:09 AM
toferdisobey
Totally understandable. If you drive in wooded areas you do need good high beams. I will take a few good night photos so you can see what it looks like.
Old 03-01-2017, 08:04 PM
PR_TL's Avatar
^ +1
Old 03-01-2017, 09:13 PM
toferdisobey
Alright here are the photos. I tried my best I hope you can see it well:
With HIDs only
With HIDs & DRLs (high beam)
DRLs only
DRLs & HIDs
The following 3 users liked this post by Christopher Michael:
echodigital (03-03-2017), Guerito (04-14-2017), Soal Man (03-02-2017)
Old 03-02-2017, 12:24 AM
Soal Man's Avatar
Thanks for the link and pics CM. About to return my Philips Diamond vision drl bulbs and get me them VLED's SMZ's. They look pretty legit from your photo comparisons. A bit pricey, but gotta pay 2 play. There goes my ski trip money smdh
Old 03-02-2017, 12:32 AM
toferdisobey
No problem. I'll be posting the vleds V3 Triton's in a week or two when they arrive. If you haven't done that upgrade yet, you might want to see those too, that way you can ship them all together. Just a thought...
Old 03-02-2017, 03:40 AM
PR_TL's Avatar
These look really nice!
Old 03-03-2017, 02:37 PM
+1 Looks great. I am probably going to get Fogs done up as well.
SMZ LED HEADLIGHT H11 H16 H8 H9 - H11 H8 H9 H16 - Fog Lights - Shop Application
Old 03-03-2017, 03:18 PM
toferdisobey
Thanks. I was thinking about it but where I live we get fog maybe once every few years so I thought that one should be last. But I did also do the trunk and door courtesy lights but I'm pretty sure everyone has done those. Post your photo when you're done ^^
echodigital (03-06-2017)
Old 04-14-2017, 12:39 AM
toferdisobey
Alright guys, vleds.com had a longer delay but my V3 Triton blinkers (front and rear) finally arrived today. I have videos showing the results, just ask. I also wanted to let you guys know that the install is a bit more difficult on our cars vs. other cars. The way Honda built the lenses and the location of wires is clean, but also makes it difficult for upgrades. If anyone needs help, I can walk you through what I did to keep this upgrade clean.
STOCK
VLEDS - They flash amber when blinker or hazard lights are in use then return back to 5K White while in driving mode.
SIDE BY SIDE
I only have a video on the rear so ask if you want to see it
Old 04-15-2017, 11:54 AM
Blaze9's Avatar
What troubles did you run into when installing the turn signals? Are those switchbacks? I can't tell if it's just a super bright yellow/amber or if it's white. Looks incredibly bright, I'ma bit jealous =P
Old 04-15-2017, 05:34 PM
toferdisobey
Main troubles were room for the rear, and location in the front. Our rear lights are a super tight area. So there's a few things you have to do but it's not that bad. The front signals, since they are behind the bumper are a little pain to get too. Plus you have to zip tie the control box and wires to keep it clean. They are switchbacks white/amber. I got the 5K White because 6k won't match our HIDs. They look amazing in person in both modes. If you get them and need help just ask
Old 04-15-2017, 06:12 PM
Rancher2005's Avatar
Would love to see the video....
Old 04-15-2017, 06:35 PM
3rd Gear
SSTT2005's Avatar
Vleds Products are absolutely Top Of The Line Products
I don't know what choice you will make I can tell you with certainty that Vleds products are top of the line as I have made many purchases from them over the years and have not yet to date have ever even had a failed led light etc...from them. I know as far as any kind of switchbacks there are no competitors for Vleds Triton V3 series from Vleds. I would not recommend any other source for led lights I Tried some license plate lights from Jdm Astar and have had the same bulb fail 3 different times went back to vleds should have know just wanted to try a lower price... You really do get what you pay for !
Old 04-15-2017, 07:43 PM
toferdisobey
https://youtu.be/jDFMViQXo-k
There you go Right is stock in video to show the difference but it's so much better in person, trust me.
Rancher2005 (04-15-2017)
Old 04-15-2017, 09:37 PM
Looks great - thanks!
Old 04-26-2017, 10:13 PM
Bigdogs's Avatar
Hi Christopher, I've enjoyed reading though your thread and appreciate you taking the extra time to share and explain your experiences. I just recently went through helping my son upgrade the lighting on his '97 4runner. We ended up going with Opt7's LED kit for HI/LO beams at about $110 and standard phillips LED bulbs for just a few bucks each. We were very happy with the OPT7 kit and satisfied with the Phillips. I have an '09 TL tech and would love to do the very same thing you have done but the set you have chosen is $200 for the DRL/HI beams and $120 for the switchbacks while Blaze9 used SMD flashbacks for $25.
I'm curious as to what the actually differences are. Did you come across something in your research or did you just choose to go all in for peace of mind?
Old 04-26-2017, 10:44 PM
toferdisobey
Hi bigdogs, thanks for your comments. Yes indeed I did try those cheaper bulbs. I started at one around 30$. Then tried ones around 65$. And the light was so low and terrible, you couldn't see it during full sun, which is dangerous. So I opted to go professional. If I were you I would save the heartache of doing it over and over and just get what will definitely work well. Maybe just do one set a month vs. all at once. If you need more photos such as comparison, I can make some to show you what I mean. But I don't have the other bulbs anymore (the 30-65$ ones) . The other big thing for me was the plug and play and resistors. If you install a cheap bulb, you'll get the warning. Then you'll add a resistor. All those wires and it's not going to be a professional install, not to mention cutting into stock wiring :/ Hope that helps, let me know...
Old 04-28-2017, 10:44 AM
Thanks for starting this post CM. This helped me decide on LEDs for my car. I am going to post pictures of the 9005 and H11 (Fog lights) with LED this weekend as well. In the end, I chose this because I was in Canada.
Free Shipping To Canada And Usa For Putco 289005 - Silver-lux Led Kit - 9005 Pair | Tdot Performance
Free Shipping To Canada And Usa For Putco 280011 - Silver-lux Led Kit - H11 / H9 Pair | Tdot Performance
I got the anti-flicker module just in case as it was only $15 extra. It was worth it 'just in case'.
1. Try to get a weave heat sink. There are no moving parts to breakdown.
2. Have a 7.5 fuse just in case there is a problem with the DRL not working later.
3. LEDs are the way to go. The technology has changed a lot in the last 3-5 years. They are much now much brighter than the halogens. Don't buy cheap ones, you pay for what you get.
4. DRL in low and high beam is still pretty bright compared to halogens.
5. www.vleds.com's 9005 with weave heat sink appears to not be sold anymore.
P.S Thanks for posting the video of the rear signal light bulb change as well. More upgrades/mods in the future.
