Comparison of iJDMToy 1157 Switchbacks on a 4th Gen TL '09-'11
3 weeks ago I've successfully installed a pair of 1157 LED Switchbacks purchased from iJDMToy (LINK HERE).
HERE IS WHAT THE BULB LOOKS LIKE:
Thanks to Big mo and his step by step installation guide (HERE) I did it in about an hour or so.
I was happy with the switchbacks but noticed that the light they produced had a little hint of green in it and was especially noticeably after i installed a 4500k HID kit in my fogs.
HERE IS WHAT IT LOOKED LIKE:
I've contacted iJDMToy to see if I got a defective set but they stated that all sets are like that. Due to the bulb using 57 SMDs for both, white and amber, the two colors mix and produce a white with a hint of green. Their customer service was pretty fair and I ended up purchasing a second set of LED Switchbacks from them. A "Hight Power 1157 LED Switchback" that looked and worked like a mini projector and produced a pure white light according to iJDMToy(HERE IS THE LINK TO THE BULB)
HERE IS A PICTURE OF IT:
I have installed this set today and would like to share my experience with you guys as I'm sure there are a few people out there looking to get those LED Switchbacks installed.
First I've tested the bulb just to see the output color and power and I gotta tell you the bulb is hella bright. The color is pure white to white with a little hint of blue, depending on the angle of view.
HERE ARE A COUPLE OF PICTURES:
Unfortunately the way the bulb is designed, it produces(projects) a bright hot spot and does not reflect much light off the reflectors inside the housing. So the light appears to be uneven and concentrated in the middle.
HERE IS WHAT I MEAN:
I liked the color output of the new bulb set better than the old one so I had to make it work for me. I had to get rig of that hot spot and make the light reflect evenly off the reflector in the housing. I noticed that there is a plastic diffuser inside the housing, right in front of the bulb. So I took a piece of tin foil and wrapped it around the diffuser.
HERE IS THE DIFFERENCE IT MADE. BOTH NEW BULBS, DIFFUSER COVERED ON THE RIGHT:
HERE IS THE NEW(RIGHT) BULB WITH DIFFUSER COVERED AND THE OLD(LEFT) BULB
I then, after, found some left over chrome vinyl and used that on both diffusers instead of the tin foil. It almost made no difference, tin foil was as good.
HERE IS THE FINISHED PRODUCT. NEW SET OF HIGH POWER LED SWITCHBACKS FROM iJDMToy WITH COVERED DIFFUSERS:
Sorry for the long post and many pictures.
Hope this will help some of you guys to purchase the right bulb for your setup without wasting extra time and money.
Wow! Great post! I am about to buy these and have been unsure which to get... I don't care for the greenish tint of the first set, but the hot spot on the second set is a problem too
The color looks good on second set though. Didn't someone else post about switchbacks that got a smd bulb but in a different style that was more pure white??? Ill look for it
Thx for info and great pics!
two things..
1st.. that color match is good.
2nd.. what happen do your bumper?
btw the switchbacks that i got from ijdmtoy was the same as your first set.. mine matched perfectly with the 6000k drl's that i have.. which is the same as yours.. dunno why yours came out greenish..
Big mo has the same DRLs and switchbacks(first set) and was saying that his match as well. I dunno, maybe my DRLs are not the same or I got a bad set of switchbacks OR I'm just being to picky. In any case I'm more happy with my second set, now that I was able to modify the diffuser and eliminate that hot spot. Plus I still have the old set as a backup.
2012 TL SH-AWD
Thank you for write up Vroom, you did a great job showing the difference bulbs. I see you added a aluminum foil inside the housing, how is that holding up with the heat? Now I've to decide either order the 60 smd or high power projector to get the slight blue tint but I'm sure the projector bulb will be more brighter.
Any plans on the rear turn signals?
If you're having the same color match issue then maybe the high power switchbacks is your solution.
Thank you for write up Wr00m, you did a great job showing the difference bulbs. I see you added a aluminum foil inside the housing, how is that holding up with the heat? Now I've to decide either order the 60 smd or high power projector to get the slight blue tint but I'm sure the projector bulb will be more brighter.
The foil should be just fine. As I mentioned before, though, I've later found some left over chrome vinyl and used that instead of the tin foil. Tin foil is more heat resistant though.
I have not looked into the rear turn signals yet but I will very soon.
Thanks for the comp. I like those ^ the best, but if it doesn't make my car drive faster, corner better or toast a Hyundia at a green light I just don't want to spend money on it. Cuts into my beer fund.
^^ amen! luckly i live a few blocks from IJDMTOY store and they were looking for someone to test their new bulbs when they came out, i got a free set just for being there 10 mins while they wired it up for me
Looks good,I have the same as your original switchbacks and mine are greenish also, and its driving me nuts!
Just a question about how they flash though, with the lights on do they flash orange-off or orange-white when you signal? Thanks.
sdelia (12-02-2012)
i bought yoru exact bulbs... i am about to try the install... do i get at the turn signal housings from the wheel wells??
you were able to remove the light housing completely to put the tinfoil into them and diffuse the light... is it hard to get the entire housing out? does it come out the back..then pull it out via the wheel well? looking at the car from the front and bottom / top... i don't see any way to get access to the bulbs or the housings from the front or bottom of the car..nor via the hood.. looks like i need to go via the wheel well...
forget my last post... i was farting around under the car and saw the 10mm bolt..unscrwed that and the housings popped right out.
spent a couple hours and got the bulbs in.
only issue I had is the ijdmtoy bulbs did NOT fit the sockets perfectly. I noticed they wuld wiggle slightly and then that woudl cause the bulbs to either turn off or not cycle from white to amber correctly. what i did was fold a small piece of tinfoi and jammed it down the side.. not far enough to interfere with the prongs at the bottom..just enough to wedge the bulb in place so it wouldnt' wiggle..that held them in tight. otherwise the color/brightness of the bulbs is prefectly find for my wants/needs and the price was right.
i'll ost up some pics later.
thanks for these writups gys. the info sure did help espeically the info about which wires to tap into.
emailnatec
29
09-28-2018 04:27 PM
SinCityTLX
10-07-2015 01:24 PM
RSpyder
09-30-2015 12:46 AM
