Sponsored by: DashLynx
Beeping noises
Old 04-17-2011, 03:47 PM
MICKWOODLYN's Avatar
Beeping noises
Anyone find all the warning beeps on the tl as annoying as i do. I'd love to disable the screeching noises i get when i walk away from the car when it's running. At least acura should have given us the option of lowering the volume of these sounds.
Old 04-17-2011, 04:02 PM
VQPower37's Avatar
i dont find it annoying
Old 04-17-2011, 04:14 PM
vinnier6's Avatar
i am not bothered by it either....
Old 04-17-2011, 05:18 PM
BLEXV6's Avatar
Well it'snot as annoying as the voice in the TSX, and they want to make sure you know that you have the key and are walking away from the vehicle.
Old 04-17-2011, 06:31 PM
Treblig's Avatar
I thought there was a way to lower the volume at least. I'll need to re-check the manual.
Old 04-17-2011, 07:09 PM
Jason717's Avatar
I think that you can adjust the volume on the MID...
Old 04-17-2011, 07:47 PM
silkysmooth_96's Avatar
Let me know if you find the way to reduce or kill the beep when walking away with the car running. I figure one can always put a relay tied to ignition so it disconnects the beeper when running, but will enable the beeper for the regular door lock beep (assuming it's the same beeper as I think it's from the rear of the car). Pretty simple mod..
Old 04-17-2011, 08:25 PM
Mr Marco's Avatar
Hate the beep! If your too stupid to remember to turn off your car when you get out of it, they should take your drivers license away.
Old 04-17-2011, 08:26 PM
Jason717's Avatar
I think it may be under keyless set up on the MID. There should be an alarm volume which you can set to high, med, or low. Not positive, but I think I saw that last time I changed a few things.
Old 04-17-2011, 09:03 PM
jasonwdp10's Avatar
annoying a small number of TL owners is much better than having idiots leaving the car on overnight and possibly killing themselves in the process..
much like the seat belt chime, safety first.
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Beeping noises
