2013 Acura TL Technical Service Bulletins
Old 05-13-2016, 08:01 PM
Forum Contributor
EE4Life's Avatar
Received 1,392 Likes on 644 Posts
2013 Acura TL Technical Service Bulletins:
TSB 12-028 - 2013 TL: TQI Information
Applies To: 2013 TL - All
http://www.urvi.net/forumfiles/SB/B12-028.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-028.PDF
TSB 08-041 - 2009-13 TL: TQI of the Navigation System
Applies To: 2009-13 TL With Navigation - All
http://www.urvi.net/forumfiles/SB/B08-041.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B08-041.PDF
TSB 12-041 - Front Suspension Clunk in Hot Weather
Applies To: 2009-13 TL - All
http://www.urvi.net/forumfiles/SB/B12-041.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-041.PDF
TSB 13-024 - MIL Comes On With DTC's P0300 Thru P0306
Applies To: 2013 TL SH-AWD - From VIN 19UUA9...DA000001 thru 19UUA9...DA005530
http://www.urvi.net/forumfiles/SB/B13-024.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-024.PDF
TSB 14-006 - MIL Comes On With DTC P0455 and/or P0456
Applies To: 2012 TL - All - All
2013 TL - 2WD - From VIN 19UUA8...DA000001 - 19UUA8...DA000686
2013 TL - SH-AWD - From VIN 19UUA9...DA000001 - 19UUA9...DA000191
http://www.urvi.net/forumfiles/SB/B14-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-006.PDF
TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction
Applies To: 2009-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2006-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 14-049 - Gurgle or Chirp from Under Hood at Cold Start-Up
Applies To: 2012-14 TL - ALL with A/T - ALL
http://www.urvi.net/forumfiles/SB/B14-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-049.PDF
TSB 15-013 - Driver’s Seat Cushion Cover Comes Loose
Applies To: 2012-14 TL - Advance, Advance with SH-AWD - ALL
http://www.urvi.net/forumfiles/SB/B15-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-013.PDF
TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator
Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF
TSB 16-046 - Judder from the Torque Converter Lock-Up Clutch
This bulletin is replaced by 18-047, 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-046.PDF
TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations
The bulletin is replaced by S/B 19-006, Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B18-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-009.PDF
TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026)
http://www.urvi.net/forumfiles/SB/B18-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF
TSB 18-047 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2012 TL - 2WD - From VIN 19UUA8F...CA035307 thru 19UUA8F...CA040693
2012 TL - 4WD - From VIN 19UUA9F...CA011186 thru 19UUA9F...CA012783
2013-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-047.PDF
TSB 18-048 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B18-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-048.PDF
TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-006.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-021 - Warranty Extension: Steering Feels Heavy, EPS Indicator Blinks with No DTCs or Comes On Steady with DTC 32-09, 32-08, or 61-04
Applies To: 2012-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-021.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B19-021.PDF
TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator
http://www.urvi.net/forumfiles/SB/B19-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF
TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B19-052.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-052.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 1999-14 TL
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030)
http://www.urvi.net/forumfiles/SB/B20-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF
TheMuffinMan (05-17-2016)
Old 03-07-2019, 10:10 PM
dregsfan's Avatar
So the replacement inflator is no better than the original? WTF??? I wonder why the recall is VIN dependent though. Did some vehicles get different replacement inflators than others?
Old 03-12-2019, 09:41 AM
lbotez's Avatar
Recall on Recall of Takata driver airbag
Seriously, I can't believe I have to go through this again.
March 6, 2019 NHTSA CAMPAIGN NUMBER: 19V182000
Driver Frontal Air Bag Inflator May ExplodeAn explosion of an inflator within the driver frontal air bag module may result in sharp metal fragments striking the driver, front seat passenger or other occupants resulting in serious injury or death.
The affected vehicles received a replacement driver air bag inflator as part of a previous Takata inflator recall remedy or a replacement driver air bag module containing the same inflator type as a service part. Due to a manufacturing error, in the event of a crash necessitating deployment of the driver frontal air bag, these inflators may explode.
Meh.
Old 04-19-2019, 07:38 AM
lbotez's Avatar
Recall on recall
Yep. I just the paperwork in the mail to call the dealer and have my driver airbag inflator replaced AGAIN... Oddly though, I thought they were going to replace the passenger airbag, but never got one on that one.
Old 06-28-2019, 06:52 PM
mrphilipanderson's Avatar
I am so incredibly confused. Is this a re-publish of the same as a reminder ? Or do I actually have to go in and get a SECOND airbag replacement ?
Old 06-29-2019, 11:46 AM
Forum Contributor
EE4Life's Avatar
No, it is different. If you had the previous recall done with a Takata driver's airbag inflator (like for like replacement part), then this new recall is to replace it again with one from another supplier (not Takata).
This post helps explain things in detail.
https://acurazine.com/forums/fourth-.../#post16445876
Old 07-01-2019, 03:48 PM
Called My Acura Dealer and their response to my asking them about this: " I checked your VIN and you dont need any recall procedures done. WHO DO I BELIEVE? I dont want to die from Shards of metal exploding in my face.
Old 07-01-2019, 03:49 PM
dregsfan's Avatar
There was a recall of replacement inflators (a few months ago, I think) that was VIN dependent. My car doesn't have one of those affected VINs, so presumably my car didn't get a defective replacement inflator. So are ALL replacement inflators now being recalled?
Old 08-31-2019, 05:32 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations.
Old 11-08-2019, 09:13 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram.
Old 03-12-2020, 07:30 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030).
EE4Life
12-20-2022 05:16 PM
EE4Life
03-12-2020 07:30 PM
EE4Life
03-12-2020 07:29 PM
EE4Life
03-12-2020 07:29 PM
EE4Life
05-14-2016 07:14 AM
Quick Reply: 2013 Acura TL Technical Service Bulletins
