Key fob no longer chirps
Old 03-19-2008, 10:52 PM
dP-
dP-'s Avatar
I've got a weird one guys. A couple of days ago my key fob stopped chirping when I pressed the fob twice (the car acknowledged the lock command as the vehicles lights flashed and the key fob's LED lit up). I was a bit surprised so I stood and looked at my lock (drivers) and noticed that only it did not lock. The rest did. I locked the car manually (key) and left.
After leaving I returned and found I could not unlock the car with the key fob. I had to manually unlock with the key. Again, the lights on the vehicle flashed as if acknowledging and the LED lit up.
I'm using the TL Switchblade, so I decided to try my old key fob (maybe bad batteries in the switchblade fob). Nope. Old transmitter doesn't work either; same thing, lights flash on vehicle but driver's door does not lock or unlock.
Anyone have an idea on what happened? Can't think of anything I did recently which may have caused this.
Old 03-19-2008, 10:58 PM
PACman's Avatar
Sounds like your driver's door lock actuator is busted. What year do you have? Since I don't have the TL switchblade key, I can't comment on the chirping as my key fob has never chirped.
Old 03-19-2008, 11:07 PM
Boring Teacher
spoiledkari's Avatar
I have the TL switchblade key and my key had NEVER chirped. My car beeps, but not the keyfob itself. I didn't even know that it would do such a thing. That would get annoying for me...I'm glad mine doesn't do it.
Old 03-19-2008, 11:17 PM
JDM Addict
MMsTSX's Avatar
I too have the TL switchblade key/fob.
It does not chirp. The car chirps, not the key fob.
Old 03-20-2008, 12:51 AM
SSM FTW
luder917's Avatar
sounds like a bad door actuator to me
Old 03-20-2008, 09:01 AM
dP-
dP-'s Avatar
I should correct the title...the car no longer chirps (not the key fob). The year is 05...sounds like I have to take a trip to the dealer then...
Old 03-20-2008, 11:55 AM
2011 M37x
blacktsx05's Avatar
my driver side door actuator is busted. and im not in warranty anymore
Old 03-20-2008, 12:49 PM
PACman's Avatar
If you can do the work yourself, you'll save about $200. The part is like $25 or $2.50, can't remember the exact amount. Do a search....Kenny did the job and posted a DIY.
Old 03-21-2008, 11:00 AM
dowzer's Avatar
If the doors are not all locked then you won't get the acknowledgment from the security system. So you won't get the honk/beep nor will the parking lights flash. This happened to me when my driver's door actuator died.
datadr
03-23-2016 01:39 PM
soupi
14
11-15-2015 11:15 AM
eastcoastguy
10-29-2015 03:00 PM
DementiaPhuro
09-29-2015 05:31 PM
malvothegreat
09-29-2015 12:38 AM
Quick Reply: Key fob no longer chirps
