# quarts of transmission fluid
Old 03-24-2003, 04:28 PM
JLK
How many to add back for automatic 98 TL and Differential oil?
Has anyone change their distributor cap and rotor? I was looking to replace these thing as the car is @ 90K miles.
Old 03-24-2003, 10:00 PM
i think 4 quarts should be enough if you are just changing the trans fluid, but if you flushed the trans completely more than four qt. are needed
Old 03-24-2003, 10:46 PM
mviper007's Avatar
HOW IS THE PERFORMANCE IF IT IS GOOD LEAVE IT ALONE???DOES IT SPUTTER IF SO IT COULD BE THE ROTOR///+///CAP MINE WENT AROUND THE SAME MILES U HAVE.
Old 03-25-2003, 08:13 AM
JLK
It doesn't sputter but figured I could give it a new one. I mean it does has 90K miles on it plus I need to change the plugs.
Old 03-27-2003, 02:33 PM
BobbysTL's Avatar
I believe there is a extended warranty by acura where they tune it up for free at 75k and then again at 150k that should include your wires, cap and rotor. I believe that is the case. Hope that helps.
Old 03-27-2003, 02:37 PM
JLK
I haven't heard of such, is that something up in NYC or all Acura dealers? Where did you get that info? If so then I will take that..
Old 03-27-2003, 07:35 PM
Slagboy's Avatar
I believe this is what BobbysTL is referring to:
http://www.4acura.com/service/updates/98-031.asp
However, it appears that '98 models are not included
Slagboy.
Old 03-31-2003, 09:26 PM
jlk i changed my plugs put in some bosh 4+'s it imporved performance imensly and made the ride alot easier apparnetly my stock NGK plugs were misfiring alot
SidhuSaaB
05-30-2020 12:40 AM
steve
09-30-2015 09:23 PM
hpfiend
09-27-2015 06:59 AM
mellsonnj
09-24-2015 04:42 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: # quarts of transmission fluid
