Need to id cooling system part betw. motor and firewall
Old 07-10-2011, 08:40 PM
PSC
PSC's Avatar
Can someone help my identify what part this is so that I can buy and replace it?
The part that I need is a black device that connects two sections of coolant hose going from the back of the motor to the firewall.
I have no idea what it is and I couldn't find it in any diagrams.
I will take a picture of it.
Does anyone know what this is?
Today the hose detached and coolant splattered all over the firewall behind my motor. Apparently the solid pipe on this part that the hose connects to broke, leaving only a short piece for the hose to clamp on to.
I was able to clamp it on for the short drive back home, but it popped off again as I was pulling in.
Please help.
Old 07-11-2011, 12:43 PM
PSC
PSC's Avatar
That's the part in the center. Need to id cooling system part betw. motor and firewall-ajg5i.jpg
This shows the location.Need to id cooling system part betw. motor and firewall-quuz3.jpg
Someone please tell me what this part is called.
Old 07-11-2011, 12:45 PM
ton8383's Avatar
heater control valve thats what makes you have heat is there a small cable attached to it?
Old 07-11-2011, 01:18 PM
PSC
PSC's Avatar
I don't see a cable attached.
I looked up that part name and I found it at autozone
http://www.autozone.com/autozone/par...questid=603039
Thanks for your help.
Has anyone changed these before? It looks like it should be simple but I would appreciate any tips. Thanks again.
Old 07-11-2011, 01:23 PM
ton8383's Avatar
there should be a cable attached to it on the lever part i never changed one on a tl i did an accord it was cake
ton8383's Avatar
in you pics looks like there isnt too much room thats it
Old 07-12-2011, 08:56 PM
PSC
PSC's Avatar
I changed it today. I removed two brackets, one that holds that big black box in the second picture, and the bracket that the heater control valve is connected to. It's visible in my first pic, the flat surface with the screw head showing.
That gave me enough room to operate.
I just loosened the clamp behind the valve and pulled it out of the rear hose.
Connected the new valve to the front and back hoses. There's also a metal arm that comes out of a nearby cylinder that needs to fit into a white plastic stopper that's on the driver's side of the valve. I fitted that into place and then reinstalled the bracket that the valve was on, and then the larger bracket above it.
That's it. It could have taken me less than an hour if I moved those brackets at first.
Thanks for the help.
Old 07-13-2011, 05:16 PM
大日本帝国
Go90go's Avatar
Damn, good deal. I smashed mine and just connected the hoses because the dealer wanted $140 at the time.
~Cheers~
Old 07-13-2011, 07:58 PM
PSC
PSC's Avatar
If you can just connect the hoses, what purpose does it serve?
I was considering that also.
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
Rcelestino93
09-11-2015 12:15 PM
Quick Reply: Need to id cooling system part betw. motor and firewall
