Here's my turbo set-up!
"VA'S FINEST"
this is what I have!
Gerret T3/T4 turbo, custom 2 3/4in wide from flex pipe to exhust, MSD ignition, greedy intercooler, AFC II controller, boost retard switch, waste gate, down pipe, universal fuel pump, custom exhust manifold, and greedy air and turbo guage pods!
Received 2,773 Likes
i dont get it wheres the actual turbo at? and did you move your battery? and if possible id like to see your custom exhaust
"VA'S FINEST"
Resident Troll.
1 Post
WOW.. i normally spend most of my time in the 2nd gen area but this is amazing
the t3/t4 is ancient.. but deadly!!! I have had a chance to play with the civic with a b16 and a t3/t4 with an fmic and that thing was UNBELIEVABLY fast... i can only imagine what yours is like...
what kind of boose are you running and have you had a chance to be on a dyno yet?
giggity giggity giggity
Hmmm...that's kinda weird, unless I am wrong. Isn't the turbo usually forcing the air directly into the manifold, instead of a pipe leading to the manifold? I am fairly novice when it comes to turbos, so I may be wrong..
Boost-N-TL: ahh i see couldnt see where it was in that other picture cause of the weird angle. anyways very nice. im guessing no BOV?
"VA'S FINEST"
nah. if that were the case you would have to have pipeing from the exhaust go up to the turbo attached to the manifold and then some more piping to bring the exhaust back down to the cat and out through the muffler. that would just be too much piping. itd be easier to just have the turbo by the exhaust and have a pipe on the intake side of the turbo goto the intake manifold. (or in his case to a fmic and then to the manifold.)
Received 2,328 Likes
Have you done any 1/4's ?
S L I C K...someone has finally proven that performance CAN be extracted out of the 2.5tl.
How did u get the soft blue lighting around the instrument cluster. All u would need are red lit needles to give it that VW instrument panel look (or 04Tl instrument cluster for that matter,)
Nice, job Boostntl, keep up the good work, but make sure you preserve the luxury identity of the TL at the same time!
7th Gear
WOW-But how?
This is absolutely brilliant, this car. WOW....
But Im confused.. i have a 96 3.2TL and i cant find ANY intakes or turbos or exhausts or anything for it...
did you do an engine swap in this thing so you could by parts compatbile with it?
i dont know that much at all by the way... but thats why im asking
so your intake and exhaust are custom?
how much did that cost you?
Good points Longeye.
When looking for intakes on the 3.2 TL's, you're better off looking under 91-95 Legends. As mentioned make sure you know if you have Traction Control or not, as the intakes are slightly different.
the cost for the acura legend injen intake is about $150 and weapon-r is about the same i did forgot how much i paid, somtimes u can find the weapon-r intake in ebay. the exhuast tip is also find in ebay diffrent name brands. but the custom exhuast system(cat back)u have to go where thay make custom exhuast pipeing, i payed about $100
7th Gear
wow... custom pipes for your TL was only $100? I thought it would have been way more. Do those pipes and that new muffler boost yor ride at all.. noticeably i mean?
damn i thought of baggin my ride but some guy i met with an s10 on bags told me that you get unusual tirewear, plus your camber is always off and cornering sucks. is this true? your ride's crakkin dunked like that. love the lip on your rims how deep is it
I think I have seen this TL on Honda-tech. I called the shop I believe Nu Image about the setup if its the same car. I wish Boostntl would give us all some more info and reply to his thread. When I talked to the shop earlier this year they told me it was like a 7K setup since it was all custom fabricated. Ran 14s in the 1/4, had bad traction problems far as still spinning in 2nd, and needed to switch torque converters. I hope he reappears!! I'm thinking of getting a 93 Vigor 5 speed for 1K and doing something like this on the vigor or my own 2.5!!
i was thinking about gitting a type 2, 3.2l legend engine with 36k and tune it up with a custom turbo, i seen it done before. but first im working with the exterior & interior all custom then ill work on the performance. right now its all showoff.
"VA'S FINEST"
