Having 3 oil leaks fixed. Does this sound right?
Old 05-02-2012, 07:58 PM
5point9Limited's Avatar
1996 2.5 162,500 miles.
Oil filter neck seal was fixed months ago-- bone dry now.
However, the car is still leaking pretty badly. I top it off every 500 or so about 3/4 quart. I smell it burning off the exhaust after a high-speed trek. I was never able to pinpoint the leaks and just dealt with it.
I needed new tires, so I brought it to the shop for tires and oil change. Asked to diagnose the leak. I got a call back and they told me that the distributor, valve cover and cam seal are all leaking.
I printed out a lot of info from the forums about the distributor, but never heard of the cam seal going bad.
I blow smoke after idling for a bit then giving it gas-- it then clears. Could the cam seal cause this?
They quoted me about $550 to fix all 3. Should I have them do another timing belt while they are in there? It has 58k on it.
Recap:
-Cam seal bad... common? Sound right?
-Blowing smoke after idling for a bit-- then it clears. Could the cam seal leak cause this?
-Should I have them do another belt?
-Any other input?
Thanks guys!
Old 05-06-2012, 08:48 PM
Ended up needing a new distributor.
zypkode (06-20-2012)
Old 05-06-2012, 09:41 PM
main70072's Avatar
How was the road trip?
Old 06-20-2012, 05:17 PM
zypkode's Avatar
I have a 96 Acura TL 2.5 with 250,000 miles. My Distributor Cap is cracked. How much did it cost you to have it repaired? And How much time did it take?
Old 07-29-2012, 06:50 PM
ellemaJade's Avatar
96' 3.2 TL Has Baddd Oil Leak Supposedly..
Recap:
-Any other input?
Thanks guys!
My TL Has a BAD oil leak like you described in your POST.
And it smokes after idling or coming off the highway to a stop.. but then clears.
What could this be?????
IIDXholic
10-08-2015 07:53 AM
Frathora
09-28-2015 11:29 PM
Iain MacLeod
09-17-2015 01:01 PM
winkyyy
09-11-2015 04:40 PM
JnC
09-11-2015 06:06 AM
Quick Reply: Having 3 oil leaks fixed. Does this sound right?
