Wheel offsets
Ok guys, I have a 98 RL and I'm looking to put some 18's. I would like a deep lip but not too aggressive. I just don't know what offset to go with without the wheels sticking out. I want to be able to tuck them. It isn't lowered yet but that's because I haven't found springs. Suggestions on offset? Thanks.
use an online wheel offset calculator to help you visualize
https://www.1010tires.com/Tools/Wheel-Offset-Calculator |
(Post 16446839)
I did not know the specs off hand, so i googled.
https://www.wheel-size.com/size/acura/rl/1998/ there are two wheel sizes, but lucky for you,both have an offset of 55 6.5Jx16 ET55 7Jx16 ET55 for more information; because I didnt know what ET stood for. Offset is stamped on a wheel as an ET value, which refers to the German phrase Einpress Tiefe. ETindicates the distance between the mounting surface and the geometric centre of the wheel (the symmetry axle), usually expressed in millimetres. When the ETvalue decreases, the alloy wheels will protrude further out. according to that definition, the high offset of 55 means that they wont stick out that much |
(Post 16446877)
Originally Posted by Royal50
(Post 16447261)
Thank you.
sadly, i think it's just us in this conversation.
(Post 16447649)
[QUOTE=justnspace;16447805]https://www.stancenation.com/2013/01...able-acura-rl/
https://www.stancenation.com/wp-cont...95-640x426.jpg https://www.stancenation.com/wp-cont...05-640x426.jpg https://www.stancenation.com/wp-cont...35-640x426.jpgthanks for sharing. A lot of those I seen on Google as well. I was just hoping someone would pop in here and show theirs so I would know the offset they used. |
From experience, those are very low offsets.
in the website that I provided, the article states the fronts are 19×9.5 +8 ...and the rear is 19×10.5 +0 VERY LOW offsets. which he countered with camber, as to not to rub. |
from experience, here is my car...with what I THINK is an aggressive offset +22
https://cimg1.ibsrv.net/gimg/acurazi...772a33f8f0.jpg https://cimg4.ibsrv.net/gimg/acurazi...e06390107b.jpg i am running a square set of; 18x9.5 +22 those gentlemen with the +8 and +0 are EFFING crazy to run that low |
(Post 16447919)
https://cimg1.ibsrv.net/gimg/acurazi...772a33f8f0.jpg https://cimg4.ibsrv.net/gimg/acurazi...e06390107b.jpg i am running a square set of; 18x9.5 +22 those gentlemen with the +8 and +0 are EFFING crazy to run that low https://cimg4.ibsrv.net/gimg/acurazi...7d9aedeabd.jpg |
what is the width of the wheels?
18" is the diameter and +20 is the offset. missing the width. +20 is pretty aggressive, depending on the width. |
(Post 16448069)
You will have to do what those gentlemen did; play with height, play with camber, play with tire size, play with fender to get them to fit.
Your proposed set is more aggressive than my set and I had to roll and pull fenders, and raise my shit up, in order not to rub. But of course, I like race car tires! Wide and fat. You will have to play with all variables, especially tires. You will have to stretch tire or put a narrow ass tire on that wide ass wheel You won't be able to tuck with springs, you will need coilovers or air |
(Post 16448600)
(Post 16448850)
That's why I was thinking of going with 19x8.5 front and rear with like a 22 to 25+ offset. I would love air or coilovers but not for my daily...too expensive.
you still will have to play with the variables to get them to fit. |
