Evaporator Drain Plug???
Old 02-03-2008, 11:46 PM
Jimmay's Avatar
When ever i accelerate, i get the sound of sloshing water behind my dash. It goes away after driving for a while. I dont get any water inside, but i think the evaporator drain plug might be clogged. I went under my car earlier and i pulled leaves out of a hole, but i dont know it thats the drain hole. Does anyone else have this problem and know how to fix it? Also the cabin airfilter, does anyone know a place where i can pick one up for cheap, i called pepboys and they wanted like $80. Working at jewel, thats about half of my check so i kinda want to find one for cheap, but i dont want a pos filter. Thanks!
Old 02-04-2008, 12:49 AM
Ultimate DIYer
97_RLer's Avatar
Sound like you have air bubbles in the coolant upper hose. In this case, your temp gauge will up and down slightly when you are driving. You need to bleed the air bubbles by unscrewing a bleed screw located at the end of the upper hose to the engine side.
Old 02-04-2008, 12:08 PM
Jimmay's Avatar
are there any markings on the hose or is it a certain color? thanks
Old 02-04-2008, 02:18 PM
Ultimate DIYer
97_RLer's Avatar
You can see the bleed screw if you take the engine cover off. It is also written on the owner's manual. Just look up the basic maintenance chapter.
Old 02-04-2008, 11:10 PM
Jimmay's Avatar
wooo!
I just did it and it seems to help. Thanks
Old 02-05-2008, 01:43 AM
Ultimate DIYer
97_RLer's Avatar
wooo!
To completely bleed the air bubbles in the upper hose, you need to open the bleed screw and then add more coolant into the radiator filler. Some coolant will flush out of the bleed screw but continue it until no air bubble comes out of the bleed screw. This must be done whenever you change coolant.
FYI: Put a towel underneath the bleed screw so that it absorbs the flushed coolant.
Mike734
12-10-2021 01:25 PM
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
Joe Avesyan
09-29-2015 03:57 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: Evaporator Drain Plug???
