Wiper woes
Old Feb 28, 2016 | 03:13 PM
vtecgobahhh's Avatar
Wiper woes
Hi guys, so the problem I've been having it the wiper banging the A pillar. At low speed it doesn't happen as often as the higher wiper speed. I read that it was the white seals and to replace the arms. Trying to figure out which arm that is.
Old Feb 29, 2016 | 09:08 AM
Jdrum1's Avatar
https://acurazine.com/forums/problem...-issue-931179/
Old Mar 6, 2016 | 10:20 AM
deltalima's Avatar
Common problem ; I just did this repair. I replaced part # 12. ( Bushings are built in) . One word of advice take many pics of the orientation of the wiper mechanism after you remove it from below the windshield and before you start moving and replacing parts! I didn't and I wasted 2 hours trying to figure out the proper orientation of all the parts as the multiple moving parts makes it a Rubik's cube for dummys moment. Otherwise relatively easy repair.
Old Mar 6, 2016 | 10:46 AM
01acls's Avatar
Op,
Each case may be different, its best to have a visual confirmation of the defective part(s) before ordering the part(s) and starting the repair. Anything less is just guessing. 02.
Old May 18, 2016 | 08:50 AM
Ended up replacing the white bushing and the problems went away. Kind of hard to see it, but you can see where it came off.
Attached Thumbnails Wiper woes-20160306_122943.jpg   Wiper woes-20160306_122903.jpg
Krisbo26
Mar 15, 2018 08:51 AM
bird jam
Feb 25, 2016 06:25 PM
venom0713
1G RDX Problems & Fixes
Feb 20, 2016 02:35 AM
kuzdu
Feb 11, 2016 06:34 AM
Carbon Pearl
Jan 26, 2016 06:20 PM
