Oil in my radiator
Oil in my radiator
Hello all, my 07 RDX has oil in the radiator, compression test is ok and no water in engine oil or transmission and I know the turbo uses both oil and water for lube and cooling but I don't know how the two can mix. It has 180,000 miles but I don't know any service history , only had it 2 months. Thanks for any help .
Oil in coolant
keep us posted on what you find.
i was hoping for your sake it is ATF fluid in the coolant ( as the ATF has a cooler that runs through the radiator), but if it is oil from the motor then you have a really bad issue.
maybe head gasket ? Turbo ? Or worse a crack somewhere in the engine
I'd also be willing to bet on internal radiator failure, even if it's a new rad. Could have been defective from the get go. Maybe try pulling the tranny dipstick or draining a bit of fluid to see if there's any evidence of contamination there as well? Same with motor oil.
+1 on being ATF instead of oil. Internal radiator failure is not uncommon, i take it the 'new radiator' was from the previous owner? I'd just go and get a DENSO replacemenet and flush the transmission and put in new Honda Type II coolant
I haven't done a dye test and there is no sign of water in the oil or trans fluid and the radiator is a Denso but , yes it could be leaking. I keep looking ,thanks all
Found the leak, some hoses near the turbo, had to pull the intercooler and the air box ,also a good time to inspect the wastegate maybe correct the pesky 2263 code. Found some suspicious vacuum lines too.
libert69
07-15-2009 11:16 AM
