Blank HVAC Radio Display
Old Jul 15, 2019 | 10:11 PM
Zee Horvat's Avatar
3rd Gear
2009 RDX No NAV, 140K miles.
Blank HVAC/Radio Display. HVAC works but no Radio. Found similar post from couple of years ago, but no solution. I have checked all the fuses and tried reset via battery disconnect.
I have no wiring diagram, but I am curious about connection between RADIO and DISPLAY.
Any suggestion are welcome,
Zee
Old Jul 29, 2019 | 07:39 PM
Zee Horvat's Avatar
3rd Gear
SOLVED! it was radio/CD unit
After some debugging, my issue ended up being a radio/CD unit.
Battery power via key switch and fuses 12V -> CD unit (converts 12v into 5v) -> radio control unit (where all the radio buttons are) -> screen
Picked up used radio on ebay for $50. BTW my original 09 part number was 39101-STK-A021-M1 which is interchangeable with 39101-STK-A012-M1.
To get new radio code you need VIN (donor car) and CD serial # (from new unit):
https://radio-navicode.acura.com/
Hopefully it helps someone else.
Zee
Old Aug 6, 2019 | 11:14 PM
CSmoney28's Avatar
CSmoney28
Thanks for the information sorry that no one got to you.
DimondD
Aug 17, 2015 10:54 AM
AlexTheMan
1G TSX Problems & Fixes
Nov 12, 2013 12:57 PM
jblessing
Jul 1, 2012 12:09 PM
aar0n
1/2G MDX (2001-2013)
Jul 11, 2010 10:58 AM
Riga89
Apr 26, 2010 12:16 PM
