2010 RDX HID Headlight Question
One of my headlights has started turning pink and I'd like to replace both of them. In my 2010 RDX it looks like I need a D2S bulb. What brand, kelvin rating, volts, and wattage should I get?
I need to make sure I order the right ones, because I'm going to have my mechanic install them. Basically looking on RockAuto and TheRetroFitSource. Thank you in advance! |
i'd get them at theretrofitsource and just get whichever D2S bulb fits your budget. I've had great success with their in-house Morimoto brand and they're a steal at 50/pair.
If you want some higher quality bulbs, you can go for the CBI or CBH but then that doubles in price. |
I did OSRAM D2S CBI Cool Blue Intense Xenon HID 5000K-5500K, Amazon, $100:
OEM HIDs are warm in the 4300K-4500K range like early morning/ late evening sun; while, the OSRAM are in the cool range like mid-day sun during summer. It will look like pure white light from behind the wheel with the OSRAM (a hint of blue from the front as you look at it). You also can't go wrong with the Morimoto brand. I had to remove the bumper and HID headlight housing to access the rear to exchange out my HIDs. I also purchased additional black plastic clips because some were broken or missing during the install. There is a YouTube vid on how to remove the RDX bumper (probably a 30-45 min job for me to exchange HIDs). Just make sure the long ground wire that runs the length of the HID is pointed towards the ground when you insert the new HIDs. The HID will not seat correctly and it will be hard to clip in place if the ground wire isn't pointed down. Big improvement over OEM in range, brightness, and width of the HIDs with the OSRAM. |
OK Mr. Gold, one question. Did you replace your bulbs because you had to, or because you wanted to? I want to do some minor upgrades to my 2011 just for the heck of it. Something to do, something to waste money on I guess. Did it make a noticeable difference over OEM. Which I think OEM are great compared to my other car's headlights. Thanks.
Originally Posted by hues10
(Post 16385643)
The RDX HID projector lens really focuses the light very well; especially, with OSRAM bulbs. It will look like you have bi-xenon in the HIGH setting compared to OEM HID bulbs. The HID improvement was much more dramatic on my RDX compared to my MDX with the exact same OSRAM bulbs. |
eBay has the best prices for these parts that’s what I use...
https://cimg6.ibsrv.net/gimg/acurazi...bf5041226.jpeg Halfway apart so I can take out the headlight to replace the ballasts, bulbs, and igniters. https://cimg4.ibsrv.net/gimg/acurazi...38a9535ee.jpeg This might help you pick a Kelvin Color. https://cimg9.ibsrv.net/gimg/acurazi...42860893e.jpeg All the way apart to replace the headlight parts that failed only had to do this once in 140,000 miles. https://cimg7.ibsrv.net/gimg/acurazi...69d36dcd39.png Oem ballast pulled from my RDX 09’ tells you the bulbs and what watts it can use for our trucks set up. |
Originally Posted by steven94ae3
(Post 16385314)
I need to make sure I order the right ones, because I'm going to have my mechanic install them. Basically looking on RockAuto and TheRetroFitSource. Thank you in advance! Here is the thread where mrgold35 talks about the bulbs and I also posted on replacing my bulbs. I replaced them on my 2010 Acura RDX because the HID bulbs definitely have a shelf life and 8 years is getting close to the end. The new bulbs made a huge difference to my older eyes. New HID Bulbs |
I replaced mine with OSRAM Xenarc Cool Blue Intense D2S Xenon Car Headlight Bulbs (Twin) 66240CBI-HCB ($80 on Amazon) and they are 10x better than the OEM. I can highly recommend these.
