How much more does it co$t to maintain a nsx than say TL?
Old 06-06-2013, 12:35 AM
tlmane03's Avatar
Question How much more does it co$t to maintain a nsx than say TL?
Can you guys help clear this up for me and shed some insight from your own personal experience?
Where do the costs come from? Some people may say o that car is expensive to keep on the road? Not saying there wont be some extra spending for example performance tires cost more than all year tires for again say a acura TL.
What else? Is it really that much more expensive than maintaince on your typical luxery sedan?
A car that you drive only half the year (depending on your location/climate)
How much is an oil change at the dealership etc?
Old 06-06-2013, 12:38 AM
tlmane03's Avatar
If you buy a quality car with no problems and take care of it then whats so expensive if so?
Old 06-06-2013, 01:21 PM
synth19's Avatar
basic maintenance is same as any other honda. timing/belt water pump is pretty expensive though.
Old 06-07-2013, 06:54 PM
Nukem's Avatar
What Synth said. It is a pretty reliable car. Just take care of it and don't skip out on sceduled maintenance you'll be fine.
Old 06-08-2013, 10:29 PM
tlmane03's Avatar
brakes etc, lets talk some numbers not just generalities.
Old 06-20-2013, 06:23 AM
IntactACK's Avatar
I would assume brakes, oil changes and general maintenance are all the same.
I don't see it being any more difficult, like the one guy said, they timing belt service may be the most expensive. Take care of it and you'll be good.
Old 06-21-2013, 11:22 PM
jmathew34's Avatar
oil change - $60 - $80; depends on whether you like to change it or use a shop and synthetic vs standard oil
brake pads(per wheel) - $90 - $300 oem to track setup
brake rotors(per wheel) - $100 - $XXX oem to track setup
timing belt/water pump - $2000 - $3000 - depends on shop/labor/parts costs
clutch - $2000 - $3000 - depends on shop/labor/parts cost
Old 06-24-2013, 05:35 PM
ac011's Avatar
If you buying a used 91-01 NSX, expect to spend 3k-5k for maintain and repair in the first year. Check out NSXPrime
Old 06-28-2013, 12:08 PM
neveronlineilx's Avatar
Then there is the big difference in Mods, Quality high end parts will set you back a pretty penny for an NSX compared to most other Hondas and Acuras...
Old 08-05-2013, 04:57 PM
Acura_Swag's Avatar
Well obviously the nsx will be more expensive den a tl because the nsx was discontinued so parts are harder and more expensive wen found
Old 08-06-2013, 10:02 PM
Nukem's Avatar
Not all parts are discontinued. Timing belt/water pump, Valve adjustments, and new dampener(harmonic balancer) set me back $1800 Its not bad at all. If you can afford a maintenance on a TL then you should be able to handle the NSX.
runutsooh (05-22-2014)
mada51589
05-03-2022 08:54 PM
08-15-2019 12:58 PM
emailnatec
29
09-28-2018 04:27 PM
STL TL-S
09-23-2015 08:52 PM
4drviper
09-23-2015 07:42 PM
Quick Reply: How much more does it co$t to maintain a nsx than say TL?
