Gear Shift will not MOVE from PARK
I have to use the shift lock to put it in neutral and then start it, otherwise the shifter will not move from park! :wtf: And whenever I put it back in park, it gets stuck there
I have a 97 3.0..........what's wrong?
Hey, you asked. (which is why i hang out in ramblings instead of car talk
Originally Posted by GoDucksCLSPride
My prelimary evaluation tells me that somethin's broken.
Bastard......I replaced the factory air box and pulled off the old neons from before I even bought the car today.....problem happened after that.......could I have blown something or disconnected something? I finally get someone interested in the car, and this bullshit happens
Brake sensor can do that like Ken said. If it goes out, and the safety switch is not released, then you wont be able to get the car out of park unless you stick your key in the release hole next to the shifter.
Sometimes blowing a fuse can cause the same problem, so check them all out. Especially any related to the brake lights/tail lights.
I've had that happen once or twice, no fuse, no bad switch, had to turn the engine off, then start it again... shifted fine after that. Funny, my old Teg used to not know it was in park when the weather turned cold.
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
