PLEASE HELP! Dash and head lights flicker when turn signal is on
Old 02-18-2005, 12:38 PM
phlux77's Avatar
I have a 98 CL 3.0 and I have had this problem for a year now. When I got the car a year ago I notice that when I use my turn signal, all my dash lights and headlights blink and surge as if there was a short. Now I need to fix it because it is getting worse. I looked at this site about 6 months ago and someone had the same problem but I forgot what they said it was. It is NOT the alternator or battery because they are new and have been tested. Someone please let me know what this problem is so I can get it repaired ASAP. Thanks!
Other than this, I have had no problems at all and really enjoy my CL.
Old 02-19-2005, 01:44 PM
Peace, Love & Acura
ajtcl's Avatar
Hondas and Acuras use what is called a "multi-combo switch." This switch controls your turn signal indicators, headlights and dash lights. when this switch fails, any number of problems can occure. from headlights and signals lamps that fail to turn on, to what you are experiencing. I would suggest that you have this replaced. It is a tricky bit of work, and I would not suggest you try doing it yourself. The procedure for replacing this switch requires the removal of the steering wheel, and airbag mechanism. This can be potentially dangerouse to a novice. Your dealer or a good repair shop that specializes in Acura/Honda should be located and I would imagine the work should not take longer than an hour or two. Good luck.
You can expect the switch to be at least $100 used and maybe $250 new. Not including labor for installation.
Peace, Love and Acura...
Old 02-21-2005, 08:18 AM
melo72's Avatar
Mine does the same thing. It started happening after I put in my indiglo guages./ It could just be from where I tapped into though.
Old 02-21-2005, 09:54 AM
wilp99's Avatar
as long as its one of the two red wires u tapped in to itll be aiit. thats where i tapped in to mine at. and idont have a problem until i pump up my rockfordfosgate punch. and i have a cap and red top.
Old 02-21-2005, 02:55 PM
CL Fanatic
98CLMike's Avatar
I had the problem but when I wrecked mine they put a new switch in..go get T-Boned..or just buy the new switch.
Old 02-22-2005, 03:42 PM
phlux77's Avatar
Thanks for your help. I think I'm gonna get the switch rather than a T-bone. hahaha. I'll let you guys know what I come up with after I replace it.
Old 02-24-2005, 09:27 AM
fuh-Q
1998CL3.0's Avatar
mines been doing this for prolly 2 yrs now, i took it to 2 diff acura dealers when i was still under warranty and i figured it was something somewhat expensive and time consuming,
because they always told me they couldnt reproduce the problem. therefore they couldnt fix it if they didnt know what the problem was. but it doesnt do it all the time and it hasn't gotten worse due to not being fixed, so its not that big a deal.
good luck and post the final cost when completed
Old 02-25-2005, 08:51 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,465 Likes on 3,059 Posts
MMMMMMMMMMM TBone...
Old 02-25-2005, 09:04 AM
viet97cl3.0's Avatar
i have a problem with my MPH and the odo on my car.. they both dont work!!!!! my 97 cl has 125,000 miles on it but i dont know how long ago it broke, i just bought the car a few days ago.... but the engine runs ok, i was thinking of changeing it out with some aftermarket parts but not sure if theres any.... any help would be helpful
Old 11-11-2016, 11:24 AM
David Linneman's Avatar
check the price and be careful
In my home town the switch is $50.00 at orileys. Be sure to disconnect the negative and positive battery cables and let the car set of at least 30 minutes before working near the air bag.
Old 12-07-2016, 10:21 PM
9th Gear
Itr909's Avatar
My car is doing the same thing. For some reason it only does it in the morning
Old 11-01-2018, 01:07 PM
rlx015's Avatar
Considering there are more RLs available on LKQonline.com I would definitely trust 100k old part that is OEM original from 2006 to 2008 RL than to after-market brands...
Old 11-01-2018, 01:16 PM
Received 8,709 Likes on 6,716 Posts
Thanks for the bump
mada51589
05-03-2022 08:54 PM
Ny1718
09-11-2015 09:21 AM
JnC
09-11-2015 06:06 AM
theinsvnity
09-10-2015 10:22 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: PLEASE HELP! Dash and head lights flicker when turn signal is on
