Car won't start sometimes and cuts off
Old 10-18-2014, 02:18 PM
Shaqs2002TLS's Avatar
I'm helping troubleshoot my brother's 97 CL 3.0. Car sometimes starts but sometimes doesn't. If you wait like an hour then it'll start. It also cut off on him while he was driving.
We've replaced the Fuel Main Relay and the Ignition switch as well. The problem is every time a take a to a mechanic it runs fine and he said he can't troubleshoot it if everything's running fine.
Ideas?
Old 10-19-2014, 03:46 PM
AlexAcura's Avatar
Ideas?
when i first got my cl if i came out for a drive parked and waited between 7 to 15 min it wouldnt start properly.. Sounded like the car was chocking and it was below 500rpm idle then shut off..
After i cleaned out the idle air valve and intake manifold I haven't experienced the problem.
Old 10-20-2014, 10:01 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,414 Likes on 3,024 Posts
Check the IACV and TPS, those are the most common culprits
Old 10-20-2014, 06:32 PM
jtbrand89's Avatar
Had a Chrysler Seabring that did the exact same thing, wound up being the distributor. Unlike these cars the coil pack is separate from the distributor (im pretty sure??). What would happen is that the car would start up fine and after it warmed up it would randomly shut off, sometimes sputter. The coil packs were cracked, when they warmed up and expanded they began to fail. After letting it sit (on the side of the road trying to figure out what the hell was going on) it would sometimes fire right back up after cooling down and contracting. Couldn't figure it out for ever and it drove me crazy. Good luck. Hope the insight helps.
97BlackAckCL (10-21-2014)
Old 10-21-2014, 11:35 AM
(Mid-Atlantic)
^ 1st gen CL's don't have coil packs FYI
Old 10-21-2014, 07:28 PM
Here are the CEL
P0108 - map sensor
P0401 - egr
P0700 - transmission fault
P1739 - 3rd pressure switch
Old 10-23-2014, 12:02 PM
(Mid-Atlantic)
There was a recall for the EGR I believe up to 150K Miles
Old 10-24-2014, 07:00 AM
Took it to dealer and they confirmed the CEL lights and said the Gas and Brake lines were rusted. Gas line in particular was leaking. They claim we should start w/ that. My Brother is done dumping money on this thing. He plans on picking up a 03 Acura TL tomorrow.
Thx Guys
97BlackAckCL (10-26-2014)
02-25-2020 09:57 AM
jordanboi
09-05-2015 01:33 AM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: Car won't start sometimes and cuts off
