3.0CL car shudders while in gear and stopped.
Old 01-14-2006, 08:53 PM
ghost_masterCL's Avatar
ok, so I had my car on jack stands for a while because of waiting for a replacement shock for my d2 coils, and I finally got it back up and running after a week. Anyways, there seems to be tranny fluid leaking from somewhere around my tranny cooler that I installed as there is a lot of fluid on the bottom in the front. i tried to tighten the connections and I'm not sure if that fixed the leak or not, but it looks like the tranny fluid is slightly below the top notch on the dipstick.
I bought a quart to top it off since it was low, but haven't done so yet.
anyways, once I got my car back i noticed that it shuddersslightly when I'm stopped completely when the car is in any gear. I know for sure this wasn't there before, and it's not a really strong shake, but it's definitely noticeable to me. Think I can just top off the fluid and it should be good again, or should I be worrid that my tranny is fucked? besides the shaking there is no noticable transmission problems.
btw. I finally got some 20% tint on my car all around except windshield, and it looks sweet . pics later when I get a camera.
Old 01-14-2006, 10:28 PM
wontonjohnny's Avatar
may be worn motor mount/s
Old 01-14-2006, 11:09 PM
I SMELL NAWZ
SanJoseRoller's Avatar
drain completely and refill with exactly 3 quarts
if it still shudders you either have a tranny problem or fucked up motor mounts
Old 01-15-2006, 11:01 AM
goddamit, I was soo sure that the motor mounts were ok a few months ago. ah well. I'll just drain and refil first just in case.
thanks guys.
Old 01-15-2006, 07:10 PM
The new ride
Mulk's Avatar
you're supposed to refill with 3.5 quarts
Old 01-15-2006, 08:31 PM
yeah I was gonna fill with as much as suggested in the manual + half a quart for the tranny cooler.
Old 01-15-2006, 10:53 PM
The new ride
Mulk's Avatar
Old 01-16-2006, 12:11 AM
maybe the idle is too low, try cleaning out the IAC or maybe the ECU just need to be recalibrated.
recalibrate the ECU by,
unpluging the battery for 10+ minutes, then reinstall, start engine and let idle til running temp is reached, about 10 minutes, give that a try
Old 01-16-2006, 12:48 AM
it also shudders a little during deceleration, but I'm pretty sure that's not the brakes since they are less than a year old and they are rotora slotted with axxis organic pads, and I'm getting a very slight sqeek when I break. I can only hear it when I'm close to a curb/wall, and I think that's just the slots in the rotor "cutting" the pads.
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
asianspec
Cameras & Photography
34
11-04-2019 11:11 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: 3.0CL car shudders while in gear and stopped.
