tuning in ontario??
Old Mar 20, 2014 | 05:15 PM
pockets's Avatar
2014 ILX 2.4 6mt black
tuning in ontario??
heres my question
because of the new emission laws in Ontario how do you tune your car put turbos or superchargers on and tune ur car if the test requires u to plug into ur obd2 and requires vin number vehicle info ect..
its almost like you wud have to put it back to stock for the test then re install all parts including tuned ecu
plz explain
if you dont know then dont post!
Old Mar 20, 2014 | 06:24 PM
abrieluno's Avatar
Chapter Leader (Eastern Canada)
PM sent
Old Mar 20, 2014 | 06:41 PM
DynamicJ32's Avatar
If you keep the main catalytic converter/pre-cats you're usually fine with a proper tune.
Old Mar 20, 2014 | 06:46 PM
abrieluno's Avatar
He's talking about how a modified car would pass the emissions without talking everything apart, like if you put a turbo or supercharger on a stock car
Old Mar 20, 2014 | 06:53 PM
ATLS_666's Avatar
3 2 GONE
How did judy make out?
Old Mar 20, 2014 | 06:55 PM
abrieluno's Avatar
Text sent
Old Mar 20, 2014 | 06:57 PM
pearl905's Avatar
Originally Posted by pockets
heres my question because of the new emission laws in Ontario how do you tune your car put turbos or superchargers on and tune ur car if the test requires u to plug into ur obd2 and requires vin number vehicle info ect.. its almost like you wud have to put it back to stock for the test then re install all parts including tuned ecu plz explain if you dont know then dont post!
suspect..
Old Mar 20, 2014 | 07:52 PM
gnuts's Avatar
3.5 psi
I thought they just looked for engine codes being thrown. Am I in trouble with my s/c? I'm just using the comptech ECM. Im due to test in sept.
Old Mar 20, 2014 | 07:55 PM
abrieluno's Avatar
I think they changed the whole procedure on how the e tests are done and Yes they check in to that, check engine light, drained battery,ecu recently cleared
Old Mar 20, 2014 | 09:02 PM
pockets's Avatar
ya apparently once a cel has been cleared u must drive the car for 2 days b4 doing the test... but nobody has cleared this up...
Old Mar 21, 2014 | 12:33 AM
bcp0715's Avatar
6th Gear
once your ECU is test ready and has no codes you're fine. hondata makes it easier to pass the test.
Old Mar 21, 2014 | 10:10 AM
Noober's Avatar
if this is the case, thank you for the information.
recently installed pcd and have my rv6 jpipe. hondata on its way.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
vpasla1
Sep 17, 2016 07:24 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
