94 or 91 - shell 91 or petrocan 94
Old Apr 27, 2011 | 09:32 AM
valleverde007's Avatar
is it me or does petrocan 94 have benefits to the turbocharged RDX? ive switched to 94 and it seems more lively (i moved residence and now there's more convenient petrocan stations with 94 around vs before). i used to fillup with shell at 91 since that's the closest to my house then (eg. 0.5 kms away on the way home)
i know acura stated recommended minimum at 91 octane, but what do you guys use?
thanks
Old Apr 27, 2011 | 09:56 AM
Miiike's Avatar
I usually fill my Supra with shell's 91 because it has 0% ethenol, and as far as I know it's the only gas station around here that has that.
On top of that, it's a little harder to find the 94 now that all the Sunoco's are gone and only half of them kept the 94, plus I think it's also more expensive.
I dunno specifically what your compression is like on your RDX, but if it's pretty high then you likely would notice a difference from the higher octane. If it recommends 91 then you aren't damaging your engine putting it in or anything, but you might get a little more power out of the 94. Again, I don't know your engine so I'm not sure...because I see a lot of people doing stuff like put 94 in their 1990 Accords or whatever because they think they're going to get some power gain when they won't see any difference with anything above 87 because that's all the engine needs.
Old Apr 27, 2011 | 11:05 AM
foreverhonda's Avatar
Esso
I find both my Element and CL-S start better with ESSO gas for some reason so I run regular in my Element and Esso 91 in my CLS. When I first got my CL-S I filled it up with Sunoco 94 and it hesitated to start so I then tried Esso 91 and it fired up right away and still does so I never put anything else in it now, oh yeah I also tried Shell but same thing happened, hesitated to start.
Old Apr 27, 2011 | 11:27 AM
Miiike's Avatar
That's more than likely just coincidence I'd say lol, Esso used to own our fuel pumps at the airport I work at and when we'd get fuel loads from them the sheet that came with it had a Shell logo in the corner lol, they all get their gas from the same place, I guess what they add to it is what makes the difference. All I know is the Shell 91 is much cleaner.
Old Apr 27, 2011 | 02:19 PM
thanks for your reply. i have no idea what these mean but ive posted it (see RDX specs below) since you were wondering. i guess right now, ill just gas up where it's most convenient (these days, 94 petro can exists near my place, though shell 91 is not too far away)
2011 Acura RDX specs Engine.
Compression ratio (:1): 8.8
Redline: 6800 rpm
Engine type : Turbocharged aluminum-alloy in-line 4-cyl.
Displacement, liters: 2.3
Valvetrain: Chain drive, DOHC, i-VTEC® 16-valve
Horsepower @ rpm (SAE net): 240 @ 6000 rpm
Torque @ rpm (lb-ft): 260 @ 4500 rpm
Old Apr 28, 2011 | 08:15 AM
TmaX's Avatar
UA7 6MT
+1 Shell 91 religiously
Old May 11, 2011 | 03:54 PM
M T L T L's Avatar
+2 Shell 91
Thats the only liquor my baby gets drunk on
ttimberlak443
21
Oct 22, 2016 10:23 PM
BoricuaTL
Apr 8, 2016 01:08 PM
eastcoastguy
Oct 29, 2015 03:00 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
