Dating & Relationships Love sucks. Now you can cry about it…
wedding band for guys: platnium or 18k white gold
Old 01-13-2010 | 07:04 PM
ViperrepiV's Avatar
sup
Hey everyone, trying to make this decision. 18k white gold is cheaper than the platinum. But so many people get platinum. Anyone know the pros and cons of each? Is it all just "more expensive is more better?" I've even heard that platinum scratches more easily than 18k gold. Thanks
Old 01-13-2010 | 08:27 PM
wrxyboy's Avatar
1st TL-S on air in
why not look into tungsten it looks like 18k and platinum. Dont know the pros or cons of it but its just another suggestion.
Old 01-13-2010 | 08:52 PM
moeronn's Avatar
is learning to moonwalk i
FWIW, I don't think anyone will be able to tell what it is while it's on your finger and there is no reason for them to have it in their hands. Get what you feel most comfortable with - as far as weight, styling and cost.
Old 01-13-2010 | 08:57 PM
NoShine's Avatar
Stainless
Old 01-13-2010 | 09:35 PM
RaviNJCLs's Avatar
I went with white gold to save some cash, but I really like it more than platinum.
Old 01-13-2010 | 09:47 PM
Anachostic's Avatar
Titanium. Save your money.
Seriously, no one cares. The only thing that matters is that people will look at your left hand and say, "he's married."
Old 01-13-2010 | 10:55 PM
Will Y.'s Avatar
Registered but harmless
Platinum is more expensive and harder to work. White gold can be easily refinished; IDK if that is true for platinum.
I have a white gold wedding band, with 3 small round diamonds inset into the band.
Old 01-14-2010 | 11:24 AM
ILoveMyHonda's Avatar
17781708
I used to have titanium as well.
It looks pretty nice and it's pretty durable material. It was so light it doesn't feel like you have a ring on sometimes.
Old 01-14-2010 | 12:28 PM
moeronn's Avatar
When I thought I lost my wedding ring, I was going to buy a titanium ring to replace it. I found the real ring, but am still considering getting a couple of titanium look-a-likes to keep around just in case.
Old 01-14-2010 | 12:32 PM
ViperrepiV's Avatar
sup
hmmmm okay thanks. so no real benefit to platnium.
Old 01-14-2010 | 01:43 PM
1Louder's Avatar
Old Man Yelling at Clouds
I have white gold too. I don't there's any real practical difference.They all scratch over time. I'd be more concerned about the style and comfort. Mine is a "comfort band" so the inside is rounded. It's very comfortable to wear. I didn't go with any jewels or fancy designs. Just a band. Which, would be your other consideration. I'd recommend something neutral style-wise. You don't want something you'll be sick of in 10 years.
Old 01-14-2010 | 02:15 PM
stlswagger's Avatar
My first ring was 18K white gold. It scared like crazy. Expensive too with all the diamonds my wife had put in it. Still have it sitting in a drawer. Now I'm rocking the cheap stuff. Titanium and I like it more than the expensive one. Mainly because it hasn't scared in the year I've had it.
Old 01-14-2010 | 02:22 PM
moeronn's Avatar
on the scratching. Whatever you get, make sure the ring can easily be either polished or refinished to match the original design.
My ring had both polished and satin finishes, but now it's all just a dull, semi-shiny finish. It's actually okay for me, but it doesn't look like it did when new.
Also, try to get a design that can easily be resized over time. Some patterns make it completely (or nearly) impossible to add or take out material.
Old 01-14-2010 | 02:34 PM
ViperrepiV's Avatar
sup
yeah I was definitely thinking about going with a plain one. I'm just a normal guy, don't think i can pull off anything too flashy, haha. Also, I think comfort fit is the way to go, although I do like the low profile of the "sharp" one.
Old 01-14-2010 | 02:46 PM
Anachostic's Avatar
All wedding bands scare. That's their purpose.
Old 01-14-2010 | 02:54 PM
Steen27's Avatar
fyi - Platinum and white gold will both scratch to some extent... but over an extended period of time, if you have the white gold polished out to remove the scratches - eventually the "white" will polish off and you'll end up getting into the yellow gold (white gold rings are based on yellow gold rings that are dipped in white gold).
Platinum you can polish out over and over again.
Platinum rings tend to be softer than white gold rings (usually white gold rings start out as 10k or 14k yellow gold rings that are dipped into a higher grade of white gold 14k or 18k) so they sometimes tend to scratch/dent a little easier or more often.
I like Titanium or Stainless.... they have a nice clean classic look, are stronger and more scratch resistant than Platinum or Gold and can be cheaper (for stainless anyways).
If I were to change my wedding band at some point in the future, (or get a second everyday ring and keep the 18k yellow gold/diamond band for occasional use) I would seriously look at Titanium or Stainless.
G/L
Old 01-14-2010 | 03:01 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
There is no such thing as original "white" gold. It is always "yellow" gold that has to be rhodiumed. After white gold is worn for a while, it'll turn back to yellow, and you'll have to get it rhodiumed periodically to get it to look white again.
Platinum is definitely more expensive than gold, but it'll never change colors.
My advice is to get what you want, and if cost is a factor, go for the more economical choice. NO ONE will be able to tell what type of ring you have on your finger, unless you tell them.
Old 01-14-2010 | 03:15 PM
NSXNEXT's Avatar
The only issue I've heard about titanium rings is that it can be costly if they need to be resized.
Old 01-14-2010 | 03:23 PM
AMGala's Avatar
Lamborghini Aventador FTW
If for any reason your ring needs to be removed in an emergency situation, gold/platinum rings can easily be broken quickly, whereas titanium is REALLY hard to break...of course, the chances of something like that happening are very low...
I prefer the darker color of platinum to white gold, but if $ is an issue I wouldn't sweat it. Also, both white and yellow gold can be re-coated with a new layer of gold relatively inexpensively ($40-50 per time).
Another thing, since platinum is softer than gold, it has more of a tendency to bend instead of break, so in that way if something ever makes contact with it, it'd be less likely to break. But again, you have to weigh the chances of that happening.
Old 01-14-2010 | 03:37 PM
Goosew's Avatar
Platinum vs. Gold
I can't tell you how wrong this statement is.
Platinum is between 4 and 5 on the hardness scale and gold is 3. Platinum is more harder than gold. Platinum is heavier and more durable. It can be fabricated better when making complex items than gold.
diamond - 10
gold - 2.5 to 3
silver - 2.5 to 3
platinum - 4 to 4.5
ruby - 9
sapphire - 9
Source(s):
http://en.wikipedia.org/wiki/Mohs_scale_… http://www.gemstone.org/gem-by-gem/engli… http://www.gemstone.org/gem-by-gem/engli…
Old 01-14-2010 | 04:00 PM
RaviNJCLs's Avatar
Old 01-14-2010 | 04:11 PM
1Louder's Avatar
You guys with titanium rings don't have scratching problems? I have a titanium watch, and while I love how light it is it scratches like you won't believe. It looks terrible. Are the rings somehow different? I think a light-weight titanium ring would be very comfortable if it held up.
Old 01-14-2010 | 04:30 PM
Berner's Avatar
Tungsten. I will will rocking this bad boy starting next Saturday.
Old 01-14-2010 | 11:36 PM
Will Y.'s Avatar
Congrats and ....
Old 01-15-2010 | 12:14 AM
phee's Avatar
I got the Shifts
i like the idea of titanium or another strong metal. i work with my hands and i dont ever want to take my ring off if i dont have to.
Old 01-15-2010 | 12:22 AM
phee's Avatar
I got the Shifts
oooh. just saw this. thats a nice fuckin band
Old 01-15-2010 | 12:21 PM
moeronn's Avatar
What do you do? If you work with heavy machinery, you want to take your ring off, or at least use a soft metal. A guy here at work used to work with conveyor belts and almost lost a finger when his ring got caught. He pretty much never wears his ring now.
Old 01-15-2010 | 12:35 PM
Majofo's Avatar
Nice band.. and congrats.
Old 01-15-2010 | 12:59 PM
Scottman111's Avatar
1919
Or any powerful electric. My electric teacher knew a guy that got shocked and it melted his wedding ring to his finger. Pretty sure he lost the finger and the two next to it.
Old 01-15-2010 | 06:12 PM
sasha's Avatar
My husband first considered getting a titanium ring. But when the jeweler told him that it can't be resized, he decided to get a plain white gold ring.
Old 01-15-2010 | 06:24 PM
Anachostic's Avatar
A jeweler tried to scare me by saying the hospital would have to cut my finger off if I was in an accident. It was like dealing with a used car salesman.
Titanium rings are cheap enough that you don't resize them, you just buy a new one. My ring was $79.
Old 01-15-2010 | 08:40 PM
phee's Avatar
I got the Shifts
i work on cars and shit whenever i get the chance. its not my career though. i make videos and do marketing imagery :ghey:
Old 01-15-2010 | 08:48 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
....me too...
... mine is engraved inside, where it will look pretty much the same for many years to come...
Old 01-15-2010 | 09:00 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
it dosnt matter what u get, just make sure u like it
Old 01-17-2010 | 09:01 PM
subinf's Avatar
One on the right for me
If I ever get married I don't plan on getting a band.
Old 01-17-2010 | 10:30 PM
Johnny_b's Avatar
My brother got my grandfathers which is a little unorthodox. Its a woven design in gold. Really simple and original.
Old 01-18-2010 | 11:12 AM
paz840's Avatar
I have a 18K white gold band, and I've already had it resized and rhodiumed twice. Pain in the ass. I don't wear it much anymore.
Old 01-18-2010 | 12:08 PM
Hapa DC5's Avatar
אני עומד עם ישראל
Tungsten.
congrats
I'm going tungsten as well.
Old 01-19-2010 | 12:49 PM
spdy0001's Avatar
I now drive an accord....
Look into Palladium... Its in the same metal family as platinum with a lesser cost than platinum or white gold. I went with it on the recommendation of my jeweler. My wife's bands are both platinum but I didn't need that expense myself. Also the big think to consider is that palladium and platinum are pure, where white gold is simply yellow gold that is coated. Its not uncommon for someone to be allergic to yellow gold. Once that coating wears off you will have to get it recoated
Old 01-21-2010 | 06:21 PM
ViperrepiV's Avatar
sup
A lot of people are saying that white gold rings are yellow gold coated with white gold. Why don't they just make it all out of white gold?
Also, Palladium seems MUCH cheaper...
Quick Reply: wedding band for guys: platnium or 18k white gold
