Cleaning the BBQ
Old Apr 21, 2007 | 10:31 AM
Tintin's Avatar
Cleaning the BBQ
Breaking out the BBQ today as the weather here is finally amazing and wondering if anyone has any good ways of cleaning the grill?
I read that cutting an onion in half and scrubbing it on the grill as the fire is on is a very good method, anyone tried it or would like to suggest another method?
Old Apr 21, 2007 | 12:19 PM
GreenMonster's Avatar
I usually just wire brush the heck out of the cooking surface, and scrape out any excessive crud so I don't get flare ups (had a nice fire going last year).
Old Apr 21, 2007 | 12:28 PM
doopstr's Avatar
Last year I pressure washed the inside of mine. Worked pretty good. Hopefully that's not a bad thing to do
Old Apr 22, 2007 | 10:29 AM
Tintin's Avatar
Thanks guys.
I heated it for 20mins yesterday then scrapped it with vegetable oil. then re-heated it to the max. not sure if that is the best way but we did eat some bbq and no one got sick
Old Apr 23, 2007 | 09:52 AM
bgsm1th's Avatar
on to the next one...
I usually clean w/ vegetable oil prior to cooking fish...gets it clean and prevents sticking...
Old Apr 23, 2007 | 10:10 AM
joerockt's Avatar
Just dial 1911
There is this spray, Zep Oven and Grill cleaner you can get at Home Depot. Its basically a metal degreaser that works like an oven spray. I use it once a year. You just take the grills out, spray it on, let it sit and blast it off with a hose and it gets rid of all the crud. Stuff is pretty potent, dont spray it on any painted surfaces.
And if you have a stainless steel grill, 3m makes a great SS cleaner and polish...
Old Apr 23, 2007 | 12:18 PM
fuzzy02CLS's Avatar
I use a grill brush & some water in a spay bottle. Seems to work ok.
Old Apr 23, 2007 | 07:52 PM
svtmike's Avatar
Sounds painful for the dog.
The care of the cooking surface depends on what it is - cast iron, stainless steel, porcelain, etc. Weber has a pretty good guide to grill cleaning/care on their website.
http://www.weber.com/bbq/pub/grillcare/
Old Apr 24, 2007 | 08:23 PM
Street Spirit's Avatar
For those cleaning with a wire brush, check the grill before putting the food down. There were a few cases here a few years ago of people swallowing a bristle that had nestled its way into a hamburger. They ended up in the hospital.
Old Apr 30, 2007 | 02:29 PM
Pug's Avatar
Pug
Team Camel, VP for Zaino
Put a piece of aluminum foil, shiny side down, on the grate. Blast it for about 10-15 mins with all burners on "HIGH". This will turn anything on the grate into ash which will come right off using a wire brush.
Old Aug 17, 2007 | 07:59 AM
JetJock's Avatar
Heat that sucker up as hot as it gets....like a self cleaning oven does....then use crunched up aluminum foil like Pug said....or a good quality brass brush. No bacteria will survive the heat...and the crud turns to ash...easy to clean. Forget the oven cleaner....you don't want chemicals on your grill. Soap takes too long.
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
Thuneau
Oct 3, 2015 04:19 PM
jmaxima03
Sep 27, 2015 10:22 AM
