PS3 download speed slow Wired or Wireless
Both my ps3 download speeds are slow with wireless and with an ethernet cable connected. Using speedtest.net, i get 500 download, 1500 upload. With my PC i get 2500 download, 1700 upload. It is connected to a router. I dont know what to do. If any 1 can please help me out i would appreciate it. thanks!
The sizzle in the Steak
Try the gaming subforum.
Needs more Lemon Pledge
Received 2,329 Likes
You need a better router!!
In the settings for the PS3, see what the flux capacitor is set at. Post here.
I shave my change purse
Did you check the fluid level in the router? I've had it go low on me without even knowing. I thought they were maintenance free! Well they arent.
Anyways, yeah check the fluid level, I'm 90% sure that's your problem since most people overlook this.
Good call. I always forget, too.
Believe me dude, it took me hours to figure out when my speeds suddenly dropped. Everyone was telling me to power cycle the router, upgrade firmware and other silly nonsense that didn't even work.
Then I pulled out the fluid level "dipstick" on the back of the router (looks like an antenna, buts its not) and noticed it was nearly dry! They are a bit tough to pull off, but you have to give it a few good tugs straight out (Do not unscrew) and you can see the level clearly.
Sanest Florida Man
Yeah make sure you use the synthetic fluid too cause it was designed just for routers.
Stogie which router do you have and which fluid did you use? I heard it really doesn't matter but I played it safe. Since I have a linksys router, I stuck with the Linksys fluid. It was a bit more pricey but I wasn't taking any chances since I heard using the wrong fluid might cancel the warranty with Linksys.
If it was out of warranty I wouldn't care, but its less than a year old.
Arram which router do you use?
Using synthetic on a newer router (especially right out of the box) can cause the fluid to leak a bit since it's a bit thinner. This will definitely cause your speeds to fluctuate like crazy! You definitely don't want to be lagging during gaming especially on the PS3.
I use linksys routers and fluid as well, but sine I am running DDWRT, I have to mix in some WRT remover.
Arram
After a bit of searching I found a pic that I sent a friend in your situation. Here is a picture of my linksys router.
The Right Antenna is the ACTUAL antenna (note it is closest to the power cord). The one on the left is not really an antenna but is the fluid check stick (forgot the actual name). Make sure you give it a good pull or two. Should pop right out. If it gives you any problems make sure you spray a bit of WD-40 on it.
(Note) If your router only has one antenna, these models are Air Cooled and do not use fluid!! So dont try to pull the antenna off of it!! Rather you will need to check the PSI of the air in your router. Let me know which one you have so I can better assist!
Sanest Florida Man
Also have you seafoamed your router yet? Try seafoam that shit works on everything!!
It's says router cleaner right on the bottle!!
wow not 1 serious response? Im using a Buffalo router with DD-WRT. I download fine with my laptop so its not the router. Has to do something with the settings ?
Plug it directly into the modem and see if it changes. If it does you know its the router.
i counted it directly to the cable modem and its same speeds
My PC i get 3000KB/s down 250KB/s upload
Wireless Laptop - 1500KB/s down 250KB/s upload
PS3 - 400KB/s down 250KB/s upload
im using ddwrt firmware.. can someone please help
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
