Motherboard need help
Old Aug 22, 2011 | 11:35 AM
DaChef320's Avatar
Registered Member
Question seems like yesterday my motherboard died out so i'm currently buying a new one and need some opinion on these two Asus motherboard which is better and the difference between the 2?
1.
ASUS M4A89TD PRO/USB3 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
2.
ASUS Crosshair IV Formula AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
need help and sorry if i put it under console and computer gaming dunno really where i should list it under need help fast cause im ready to order
Old Aug 22, 2011 | 11:37 AM
CocheseUGA's Avatar
Might try here:
https://acurazine.com/forums/technology-16/computer-building-thread-824518/
Old Aug 22, 2011 | 11:50 AM
DaChef320's Avatar
Registered Member
need to order it now
Old Aug 22, 2011 | 02:12 PM
RJANACONDA's Avatar
Registered TL Lover
get the cheaper of the 2.
if your MB died and your buying a new one means it was at least a year old, so chances are they are better than what you had so just get the least expensive of the 2.
and if the cost the same get option 1
Old Aug 23, 2011 | 03:24 AM
Yvuru's Avatar
the crosshair is gamer-oriented therefore it costs more. it also comes with more features that i would consider unnecessary. other people might tell you otherwise
get the m4a89td pro
edit: i have the ma87td pro and its still running strong
Old Aug 23, 2011 | 04:39 AM
Moose Muscles's Avatar
Wish I would have saw this earlier.
My handle on steamforums is "Notavirus.exe" and I help people fix and build PC's quite a bit.
The answer to your question is a question.
What is the PC used for? If you answered overclocking or gaming then you want the crosshair board.
Both boards offer the newest 6.0 sata ports and USB 3.0, both are compatible with the same type of processor and both boards hold 16gb of DDR3 2000 ram (if your overclocked), both take 24 pin power cable, both have 6 sata 6.0 ports, both have NO VIDEO capability as is (you need a video card), both have the same 850 south bridge set, and both have a 3 year warranty.
So whats different your asking? The crosshair has 3 video card slots for running crossfire gpus, where as the M4A89TD only has 2.
Personally, I would go with the M4A89TD.
Hope that helps.
TLkid87
Mar 1, 2006 11:55 AM
mt6forlife
Technology
15
Dec 5, 2005 08:10 AM
01cl_blk
Feb 9, 2005 06:35 PM
Akim711
Jan 7, 2005 08:13 PM
