HARD DRIVE DYING - Need a recommendation!
Old Jan 17, 2010 | 10:32 PM
DeathMetal's Avatar
Fearless DIY Guy
Well, it would seem all things silicon-based have some sort of personal vendetta against me as of late, and, as all bad things come in 'three's', the triumvirate is complete leading me to hope and believe that this latest blow is the last to come.
My WD back-up drive is on the fritz. While I can see my folders and the properties note the appropriate size, I cannot open any of the files, be it music, photos, or anything of the MS Office-origin, etc.
That being said, I need to have this recovered before this drive becomes the donor for a new set of coasters. Whom do you recommend I send this drive out to for repair?
Oh, and in case you were wondering, the other two were a bunk Boyo VTK350 backup camera and an Arc Audio 2500-XXK amplifier.
Old Jan 18, 2010 | 09:35 AM
doopstr's Avatar
Anywhere you send it is going to charge you like $1000 or more.
Old Jan 18, 2010 | 09:44 AM
DeathMetal's Avatar
Fearless DIY Guy
First quote is $600.
This is like being held hostage.
Old Jan 18, 2010 | 10:07 AM
WdnUlik2no's Avatar
I had a hard drive fail on me, and if it wasn't for the years of work I had put in a software project I was working on, and potentially losing all my pictures of my son, I would have never shelled out the $1800 to ADR for the Recovery. Since then I had backups of all my PC's running every night. I got kind of slack in maintaining the backups these past few months, and almost got burnt again after I accidentally downloaded the AntiVirus Live virus after accidentally clicking on one of the ads on Azine. The thing is my anti Virus and Spy bot caught it and warned me but I was clicking so fast I didn't even pay attention to what was doing until it was too late. Six hours later I got it all cleaned up.
Old Jan 19, 2010 | 08:45 PM
DeathMetal's Avatar
Fearless DIY Guy
PROBLEM: Dying Hard drive
SOLUTION: Place in -30C freeze at work for +24hrs, pack in cooler, sprint home
RESULT: All files recovered, drive failed again 4 hours post-thaw
Awesome.
Old Jan 20, 2010 | 08:29 AM
litesout's Avatar
Oliver!!!
Well done! I was going to suggest something similar. I brought my laptop and USB enclosure over to a buddy's house not too long ago to recover his drive. We just put the drive in the freezer for a bit with the USB and power cables going to the laptop on the counter next to it. Worked like a charm.
Old Jan 20, 2010 | 08:34 AM
STL+3.0CL's Avatar
Matt
Awesome.
The good ol freezer trick
Old Jan 20, 2010 | 09:19 AM
JediMindTricks's Avatar
What Would Don Draper Do?
so how is it that the freezer trick works?
i know people that did it with the red ring of death on their xbox 360s.
Old Jan 20, 2010 | 10:00 AM
DeathMetal's Avatar
Fearless DIY Guy
I believe the theory is that it causes errant mechanical components to shrink, which would cause them to operate closer to original spec...
RROD was another thing altogether, that was CPU failure due to MS's shitty heatsink, easily fixable with the 'X-Brace' before MS admitted faulty design.
I was sure to throw a secondary set of fans along with an OE upgrade when I opened mine up.
Old Jan 20, 2010 | 10:03 AM
litesout's Avatar
Oliver!!!
That's one of the things. Long ago when I worked for Seagate we had a series of hard drives that was prone to overheating issues due to a faulty bearing. The freezer trick worked quite well for recovering data on those. Unfortunately, USB wasn't in existance yet, so it was a little tougher to do.
Old Jan 20, 2010 | 06:01 PM
WdnUlik2no's Avatar
That freezer shit actually works?! I tried it with another failed drive I had, but I didn't leave it in the freezer the whole time and connect it to my laptop while it was still in there. I guess it wouldn't hurt to try it again.
Old Jan 20, 2010 | 08:32 PM
DeathMetal's Avatar
Fearless DIY Guy
I am not shitting you, this really worked!!! I will say this - my HD was in what seemed to be the very early stages of failure...I am sure there are point of no return, but fortunately, mine did not cross said proverbial line in the sand.
GL, man...GO FOR IT!!!
Old Jan 23, 2010 | 02:15 PM
ChodTheWacko's Avatar
Moderator Alumnus
If you can see the files though, what is the freezer trick going to accomplish? If the hard drive was having a hard time spinning, or the drive head was acting up, I can sorta see it - but what would it accomplish for data corruption?
I'd try the freezer trick as a last resort as there is a decent change you'll kill it for good.
- Frank
Old Jan 23, 2010 | 02:35 PM
Beelzebub's Avatar
- Frank
Frank
I have done the freezer trick in the office, one of the DFU's that we work with had customer data on a drive and fried it. It worked like a charm for me to get the data off the drive. I acutally ran the recovery with the drive still in the freezer in the kitchenette plugged in with the USB IDE adapter.
james357
Feb 13, 2016 02:37 PM
redsox68
Sep 16, 2015 06:18 PM
PortlandRL
Sep 14, 2015 12:01 PM
ja17
Sep 7, 2015 06:08 PM
