get my lag lower on CS
Old Dec 29, 2004 | 01:14 PM
sixgearcl's Avatar
Registered Douchebag
i notice when my latency is ~50 i fuckin OWN CS... problem is .... its usually @ 80-100+
i got windows xp w/ sp2
i disable my antivirus, autoupdate as well as the firewall...
my setup is gateway w/ 512 (dual channel)
p4 @ 3.0 ghz
radeon pci 9250 256mb videocard
im sure there are ways tweak the console and can somebody explain "ping" to me?!?!?
any suggestiuons would be greatly appriciated
Old Dec 29, 2004 | 03:11 PM
ib_jimmy's Avatar
ping, when u request something from somewhere it doest got straight to u...it hop from one server to another...from another computer to another computer...the lower the ping rate is the smoother ur connection is.
Old Dec 29, 2004 | 07:21 PM
alex2364's Avatar
Get a faster Internet connection.
Old Dec 31, 2004 | 04:34 AM
ChopSuey's Avatar
Down The Of System
okay, there are three main commands that can control your bandwidth
In your console type
rate 25000
cl_cmdrate 60
cl_updaterate 60
these settings are for cable/dsl and for some people need to be tweaked to give best performance. These are settings I use for best performance in CS and CS/source. so use at your own risk.....
Old Dec 31, 2004 | 05:31 PM
huy33's Avatar
Here are some ways to lower your ping. I play battlefield online and my ping is only 10 while i'm at home with wireless dsl from verizon. If i'm connected through an ethernet it is like 5ish. To lowre your ping try/do these things:
*turn off AIM or anything else that use computer/internet resouces
*to play fps games, you probably need more than 512mb (1gb at least)
*run the game STRAIGHT from the harddrive instead of the cd, to do this you'll need a program like alcohol 52%
Old Dec 31, 2004 | 06:26 PM
SeCsTaC's Avatar
styling on you
stop using that shitty 512kb DSL, and go get Cable =D Oh and do this in console
rate 10000
thats the rate for cable/dsl users works great for me
Old Jan 1, 2005 | 10:17 AM
sixgearcl's Avatar
i do have cable
Old Jan 1, 2005 | 10:19 AM
sixgearcl's Avatar
rate 25000
cl_cmdrate 60
cl_updaterate 60
that was the help i was lookin for.. i managed to keep my lag steady at about 40... AWESOME...
you guys know your shit
Old Jan 2, 2005 | 07:28 PM
Hobo's Avatar
Flap.
rate above 20k has been show to decrease performance, so leave it at 20k
cmdrate should be as high as possible
and updaterate should be as high as possible without any loss
turn on netgraph 3 to see what im talking about, there are other small tweaks that ive since forgotten... suff about not drawing polygons if they are underwater and other small things that will net you .1 or so more fps... make sure fps_max is set to 101 which is also the setting i recommend for cmdrate. lemme do a little more looking as there is one more very important setting which i cant remember
Old Jan 5, 2005 | 11:41 AM
sixgearcl's Avatar
dammnit i found that my computer only puts out 30-40 fps... that sucks!!!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
rhdune16
Sep 28, 2015 11:31 AM
